M11xR1 does not recognize the battery
Discussion in 'Alienware M11x' started by Consi Pit, Sep 22, 2012.
  1. Consi Pit
    Consi Pit Notebook Evangelist
    Today I got a message - the battery is not recognized and can not be loaded, press F1 to continue, F5 for diagnosis. When I push the test button on the back of latop - light up all the lights. Almost all the time I working with power brick . Where can be a problem ?
  2. Mechawyvern
    Mechawyvern Newbie
    This happened to me a while back. Make sure the system is turned off, and then remove the bottom plate/cover. Unplug the battery, plug it back in, and reboot the system. This should get it going again.
  3. Alienware-Pablo_R
    Alienware-Pablo_R Company Representative
    That's very good advice, try a power drain. Turn off the machine, make sure no peripheral is connected. Remove the a/c adapter and the battery. Hold the power button for 30 to 45 seconds (the system isn't supposed to turn on). Then reconnect the battery and a/c adapter and check if the system recognizes the battery. If it does, you can try to flash the BIOS.
  4. Consi Pit
    It helped for this moment, thanks
  5. Alienware-Luis_Pardo
    Alienware-Luis_Pardo Guest
  6. Consi Pit
    Thanks again. One more question if You can - can I remove the battery , and safely use the computer without it?
  7. Alienware-Luis_Pardo
    Sure go ahead! :)
