M11x Wifi Issue
Discussion in 'Alienware M11x' started by Ensoniq, Mar 9, 2010.
  1. Ensoniq
    Ensoniq Newbie
    Just receieved my M11x in today and did a clean install of Windows 7 Ultimate. I have tried to use the Intel drivers suppplied by Dell on their website and the drivers supplied off Intel's website but neither of them will work. Has anyone else run into this issue after having done a clean install?
  2. abusedbunny
    abusedbunny Notebook Consultant
    are you sure the wifi adapter is on
  3. Ensoniq
    Ensoniq Newbie
    Yep, the Alienware OSD shows it as being on
  4. SVTSnake
    SVTSnake Notebook Enthusiast
    Are you sure you have the Intel 5100 and not the the Dell wireless card?
  5. Infernal_Machine
    Infernal_Machine Notebook Enthusiast
    I've the same exact issue.
    Clean install of Win7Pro, everything but the wifi drivers (either from dell or intel) load up. I get a 'hardware not compatible' error message.
    I've installed via the exe as well as a manual (Have disk) and notta. Very frustrating.
  6. DR650SE
    DR650SE The Whiskey Barracuda
    Are you guys sure you have the wireless enabled in the BIOS. It needs to be enabled prior to istalling the drivers. Also like SVTSnake stated. Make sure your using the right wifi drivers from the dell site as there are two differant ones.
  7. Infernal_Machine
    My wired/wireless options are enable via the BIOS.
    I've reinstalled the intel chipset drivers/files and use the drivers brought up via my service tag.
    Under device manager it's listed at 'Other Devices' 'Network Controllers'
    This blows.
  8. BatBoy
    BatBoy Notebook Nobel Laureate
    When you enter your Service Tag the page displays the list of drivers for the model - not for your exact configuration.
    You need to check your invoice and find the wi-fi card line to determine the card or you can check here (you will need to input your service tag, click on the original configuration tab):
    http://support.dell.com/support/top...fo/details?c=us&cs=2684&l=en&s=pub&~ck=anavml
    Look for the wireless entry.
  9. DR650SE
    Ninja mod is quick :confused:
  10. Infernal_Machine
