M11x R2 WLAN card replacement
Discussion in 'Alienware M11x' started by saturnotaku, Feb 16, 2018.
  1. saturnotaku
    Does the M11x R2 whitelist Wi-Fi cards? I'm getting one next week and would like to replace its old WLAN card with a Killer 1535. Can I do that, or is the Dell BIOS limited in this regard?
  2. Dialup David
    Dialup David Notebook Consultant
    Sorry for the delayed reply, but not at ALL. At least with the A05 BIOS, I've made my own unlocked version (T|I runs Coinhive malware on their site), but it has nothing modified to enable/disabled any extra hardware functionality. Even further, I decided to fool around with the Extra PCI-E slot that the WWAN usually hangs out in; you can actually install dual WIFI cards if you wanted to. Both of which fully worked out of the box (Did it myself today). I'm actually thinking about adding a Mini PCI-E USB 3.0 controller in the WWAN slot, then installing a high end GPS module in there. Would be a neat machine to have that level of functionality in the size. Or perhaps I go eGPU, possibilities are limitless with that extra slot.
