Lowest power consumption SSD?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by w12x, Jun 23, 2011.
  1. w12x
    w12x Notebook Enthusiast
    Looking for a SSD for my new X220
    I'm considering 4 different SSDs at this time, Intel X25-M 120GB, Intel 320 120GB, Crucial C300 128GB, and Crucial M4 128GB.
    Does anyone know which one of these four have the lowest power consumption? :)
  2. User Retired 2
    Intel does better than Crucial. Samsungs tend to be the lowest.
  3. Phil
    Phil Retired
  4. Tsunade_Hime
    Tsunade_Hime such bacon. wow
    As it's been stated, out of those 4 you'd be best off with Intel. Crucial tends to be higher performance so battery life usually suffers. Also are you talking about overall power consumption or just idle or doing tons of I/O.
  5. pukemon
    pukemon are you unplugged?
    intel or samsung.
  6. DaMarcus
    DaMarcus Notebook Geek
    Samsung 470, definitely. Phil also knows that I've checked a lot of reviews to buy the SSD with the lowest power consumption. The Samsung 470 has overall the lowest power consumption, better than the competitors from Intel and Crucial.
  7. yalcin19
    yalcin19 Notebook Consultant
    May I ask how important it is to comsume a fraction of watts more or less?
    Does one as a personal user get significant benefit out of this less power comsumption.
    For me it is pointless measure out of all SSD features and one should not take
    power consumption rates into consideration as buying comparison.
    Another pointless measure is MTBF from buyers perspective.
  8. HTWingNut
    HTWingNut Potato
    Not at all. With ULV / thin and light laptops, every Watt counts. My M11x with IGP on consumes only about 7-8W idle/surfing. If I can idle at 0.2-0.3W instead of 0.8@-1.0W then I can save a good 30-60 minutes battery. I can get nearly 8 hours battery using my Intel 120GB X25-M G2 SSD compared with only 6.5 or so with the 7200RPM HDD that it replaced.
  9. yalcin19
    I personally got nothing out of it going from HDD to SSD. Possibly negligible
    few minutes.
    I have a 54000mW battery and it runs out in ~1.5 hours. That is 600mW per minute.
    I can do some research on power usage of all the components and add them up and show you that is neglegible.
    Maybe when I have some spare time I will do the calculations for you.
  10. HTWingNut
    HTWingNut Potato
    Yes in that case it won't matter much. That's why I mentioned ULV and/or thin & light laptops and netbooks that sip power to begin with. It can garner well over an hour of battery life. I wouldn't consider the power consumption of an SSD in a desktop or desktop replacement like my Sager 17" because it would only run a matter of minutes difference.
    In the case of my Hannspree notebook that I'm typing on right now, it has 55000 mWHr battery, draws about 9000mW so gives 6.1 hours battery life (55000/9000) which is about accurate with the SSD in there. If it drew 800 mW more that's 55000/9800 = 5.6 hrs battery life = half hour difference.
    I have done tests between different SSD's and HDD's and can tell you for low power laptops it can make a significant difference.
