Lower Zenbook Power Consumption due to Asus Smart Gesture
Discussion in 'Asus' started by Duct Tape Dude, Dec 25, 2013.
  1. Eclipse_lite
    Eclipse_lite Notebook Guru
    What if i simply switch off the touch pad (Fn + F9) and use a mouse? will the battery life still be dramatically effected by Asus Smart Gesture?
  2. tomdot
    tomdot Notebook Guru
    UX303LN user.
    I believe if you don't use Smart Gestures, your CPU will not jump to 2.4ghz+ which will definitely help this situation.
    Using an external BT mouse significantly adds to my battery life. I choose not to disable gesture as it plays an important part of my laptop experience, but continue to try to use my Logitech T630 mouse when I can, where space permits.
  3. berlen
    berlen Newbie
    Is disabling gestures like zooming and rotating a workaround to this problem?
    I mean, what are the gestures that affect the CPU min percentage?
    I only use scrolling with 2 fingers.
    Thanks.
  4. Zenbook
    Zenbook Newbie
    Hi,
    towards you and the other guys with this problem:
    Its really easy to fix. If you look closly at the stuff that you copied and pasted, you will notice that there are a few empty rows ar the beginning of the document. Delete those, make sure that the xml-code starts in the very first row. Thats all. Now save it again and import it with task-scheduler and your done. Works like a charm for me, getting now around 8:30 Hours with my UX303LN (i5/256GB/8GB/840M/EU Model with 1080p) while doing office stuff.
    @DuctTapeDude: Thanks a lot for your code! It obviously helped me a lot :thumbsup:
  5. tomdot
    EDIT: pls disregard
  6. johnconnor92
    johnconnor92 Notebook Enthusiast
    Agreed. I successfully added it into the task scheduler but the core still goes up to 2.5GHz when I use the zoom gesture. I'm using 3.0.10. on UX303LN
  7. flunserl
    flunserl Notebook Enthusiast
    SOLUTION!
    I recently purchased a UX303LN as replacement for my beloved Acer Aspire TimelineX 3820TG.
    First thing I do after a clean install, is optimizing the OS for lowest noise and best batterylife.
    Not having full Control over the powerplan drove me nuts, and I was very happy to find this post and that I'm not alone :D
    Today I found the solution to this nasty behavior on superuser.com
    You can add a DWORD value with Regedit to disable that behaviour:
    In HKEY_LOCAL_MACHINE\SOFTWARE\ASUS\ASUS Smart Gesture
    Add the DWORD AutoSetMaxPower, set it to 0 and reboot.
    All credits to User JakeGould
    I can confirm, the solution works under UX303LN / Win 10 Smart Gesture Ver.405
    ;) flunserl
    nipsen likes this.
  8. nipsen
    nipsen Notebook Ditty
    Oh, wow. Thank you, thank you so much. Yes!
    edit: the kicker is probably that the scroll is smoother now, and I also don't randomly lose focus to the smartgesture program in the background with apps that have exclusive contexts.
