Lost TPM 2.0 and Overclocking problems on my GX800VH
Discussion in 'Asus' started by stefan063, Oct 26, 2021.
  1. stefan063
    stefan063 Notebook Consultant
    I have a problem regarding TPM 2.0
    After powering on my GX800 I noticed slow boot time. Black screen was almoast a minute present until ROG logo appeared. Then after booting to windows I noticed so warning related to Overclocking problem and to get back to BIOS and reset it to defaults. Did that nothing happens. Then I opened HWInfo and saw that TPM2.0 is missing also. Tried flashing BIOS again with same version. Nothing. So I have two problems. TPM2.0 and BIOS CPU settings. What can I do to try and resolve the isue?
  2. stefan063
  3. nightingale
    nightingale Notebook Evangelist
    If you have been through the bios, do you notice anything called the "overclock lock"? intel recently in the past year or so has had a patch fix to fix security vulnerabilities that turned off overclocking, but you can turn that lock off in the bios and you will be able to overclock again
    I imagine your TPM 2.0 is a similar situation where you have to turn it back on in the bios
    these settings should be under the advanced options menu
  4. stefan063
    That is the point. I don't see anything regarding OVERCLOKING nor TPM or something similar in Advanced menu, well, nowhere. All of this happened all of a sudden. Laptop just restarted on it self and after restart I noticed little delay between restart and POST screen (ROG). After login in to Windows that screen regarding overclock. I have ordered new BIOS chip from eBay and I'll see whether it will resolve the issue.
