Looking for Thin and Light with Good Battery
Discussion in 'What Notebook Should I Buy?' started by asdad123, Apr 28, 2012.
  1. asdad123
    asdad123 Notebook Evangelist
    1) What is your budget?
    $1000 USD
    c. Thin and Light; 13" - 14" screen
    United States
    No preferences on brands. I saw a Dell XPS 14z at my local micro center and I LOVE the design. If a 14z gets upgraded with Ivy bridge before I find any other types, I will most likely get that laptop.
    Yep, No problem.
    Matlab, Autocad, Web Browsing, Light Gaming (Diablo 3)
    Taking it to classes.
    Yes light gaming. Diablo 3 mainly. Would love a laptop with a 640m, but not many are out at the moment.
    5+ on web browsing.
    Online is fine.
    11) What OS do you prefer? Windows (XP or Vista or Windows 7), Mac OS, Linux, etc.
    Windows 7 or OSX
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. Click here for Screen resolution information.
    I know not many 13.3 or 14 inch laptops have a resolution higher than 1366x768, so thats fine.
    13) Do you want a Glossy/reflective screen or a Matte/non-glossy screen?
    No preference
    Build Quality and Design
    Nope. Just want it to be thin and light to fit in my medium Timbuk2
    Within a month
    2-3 years
    Notebook Components
    17) How much hard drive space do you need; 80GB to 640GB? Do you want a SSD drive?
    Will be replacing with a 256gb m4 I have on order.
    18) Do you need an optical drive? If yes, a CDRW/DVD-ROM, DVD Burner or Blu-Ray drive?
    Doesn't matter.
    I know I should really wait for the ivy bridge laptops to come out, but I would just like to see what laptops are out there that fit my needs right now. Thank you
  2. pepper_john
    pepper_john Notebook Deity
    Thinkpad X220 or T420 depending on how portable you want to be. With X220 you can choose an IPS display.
