Looking for Macbook Pro Replacement
Discussion in 'What Notebook Should I Buy?' started by ssvt, Nov 8, 2016.
  1. ssvt
    ssvt Newbie
    General Questions
    1) What is your budget?
    $2000-3000
    d. Mainstream; 15" - 16" screen
    US
    No preference but lean to Dell
    No
    Adobe CS6 and CC, Web development, database work, graphics
    70% at the desk.
    No, none at all.
    4 or so.
    W/O seeing is ok. (I've seen the Dell Precision 5510 which is what I'm leaning towards.)
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    Linux, Windows 7. Never 10 - never.
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    1920x1080 or higher. The Dell 5510 also offers 3840x2160. How great would that be? I'll never use the touchscreen - just won't. Will the higher-res cause problems? Can it be scaled down?
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Glossy is fine - preferred.
    Build Quality and Design
    No.
    Replacing my old Macbook Pro that has been my workhouse for 8 years!
    4+ years
    Notebook Components
    At least 512 SSD
    Not needed.
    _________________________
    I'm really leaning towards the Precision 5510 or 7000 series. I was planning on buying a new MBP after waiting BUT Apple has lost its way IMO. My main concern about the 5510 is whether the high-res screen is worth the extra money. My current MBP only has 1400x900 so anything higher would be icing on the cake. (And I'm not getting any younger - 61 years old means tired eyes!) Recognizing the issues I've read about Linux and the higher-res display - would I miss it? Thanks for any suggestions!
  2. win32asmguy
    The Precision 5510 is a great choice. If you want to avoid Windows 10, and are going to be using CS6, then you will have the easiest path with the FHD display. Most stuff should work fine at 100% - 125% scaling (your preference depending on eyesight).
    I know many people who preferred glossy displays because they used to have nicer looking color than older matte displays. However, there are many matte panels available on laptops (the Precision included) that have great looking color without the gloss. I don't think you will be disappointed.
    Oh, and the HP Zbook Studio is another option very similar to the Precision, in case you are looking for other suggestions. Its got a slightly different keyboard layout, a few more processor options, and has an integrated gigabit ethernet port if you think you would need to be carrying a dongle around often.
  3. ssvt
    ssvt Newbie
    Thanks for the comment. I'd looked at the HP and it (and the new Spectre) look great but we've had a few of the 5510's at work that convinced me to go that route. I agree with what you're saying about the FHD display - it will save me a bit of change too!
  4. KCETech1
    KCETech1 Notebook Prophet
    from Dell the 5510 and 7510 are the way to go. other options I have or have used for heavy CS/CC work are the Lenovo P50 and P70 ( have the 70 with xeon/m4000m/64gb ) and the HP Zbook 15 and 17. I have not had hands on with the Zbook studio but its interesting me as well. ( I have a collection of HP workstations dating back to the old infamous 8740W )
