looking for a well built ultra book with good battery life decent keyboard and trackpad
Discussion in 'What Notebook Should I Buy?' started by gerryf19, Dec 31, 2014.
  1. gerryf19
    gerryf19 I am the walrus
    Looking for a well built ultrabook with good battery life. No gaming needed, but I want a substantive notebook that isn't going to break easily.
    General Questions
    1) What is your budget?
    $1000 to $1400
    b. Ultraportable; 11" - 12” screen
    c. Thin and Light; 13" - 14" screen
    US--online
    a. Like:
    Lenovo (was aiming toward the Carbon X1, but hear bad things about the new, adaptive keyboard and trackpad, as well as the battery and new processor
    b. Dislike:
    Acer
    No
    Business. Needs to be relatively light and good battery life--no gaming
    travels with me
    no
    no less than 6, but the more the better
    not needed
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    windows 7 pro or windows 8.1 pro...need to sometimes connect to domain
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. Click here for Screen resolution information.
    Does not need ridiculous resolution (ie, retina style on macbook)
    13) Do you want a Glossy/reflective screen or a Matte/non-glossy screen?
    matte
    Build Quality and Design
    not so much
    next week
    4-5 years
    Notebook Components
    128gb ssd will likely suffice
    no
