Longevity of Seagate Momentus XT ST750LX003 Hybrid 750GB
Discussion in 'Dell' started by etcetera, Sep 13, 2017.
  1. kojack
    kojack Notebook Virtuoso
    Yes, the videos I posted were using the xt drives. Speeds of HDDs have peaked. Speeds of SSHD are increasing, as are SSD. So, those videos are a few years old now, and so, My new firecuda 2tb is faster than what are on those videos however, the HDD drives stay the same speed. The speed gap between the two are growing.
  2. etcetera
    etcetera Notebook Evangelist
    Update. The hard drive is still running and still used on a daily basis.
    I did install another HDD and cloned the primary one. So if the unreliable HDD fails, I have a backup.
  3. kojack
    You won't have to worry. It's solid!
  4. etcetera
    I am waiting for the price on Samsung 850 Evo 2.5" SATA to come down. The 1TB version sounds like a great replacement for it.
  5. kojack
    If it is working, and you are fine with the speed, I would not bother. It's not going to just up and die. But if you NEED the speed increase over the SSHD then it's a good option.
  6. etcetera
    Still keeps running with no issues. It's not my primary machine so no reason to spend funds to upgrade it to latest-greatest.
  7. kojack
    Yep...no issues at all with mine either. Getting ready to install a 1tb into my wifes dell soon. Been busy and never got around to it.
  8. Aivxtla
    Aivxtla Notebook Consultant
    With only like 8GB NAND yeah it (the flash) can/may wear out relatively fast depending on usage conditions, but once the flash wears out it simply operates like a regular HDD so don't worry about the drive as a whole actually failing.
  9. kojack
    My firecuda has a 5 year warranty, I am guessing the "reliability" of the 8gb NAND is much more durable than older models. I am on year 2 now, of heavy use and it's still much faster than my HDD in the same device.
    Vasudev likes this.
  10. etcetera
    I see that the 1TB Samsung 850 SSD 2.5" is about $170 now, is that a good buy? To replace the Seagate Momentus XT ST750LX003 that's there now?
