Longer AC adapter cord for PB70EF (Powerspec 1720)?
Discussion in 'Sager and Clevo' started by Harte, May 28, 2019.
  1. Harte
    Harte Newbie
    Hello, I have a Powerspec 1720, which I believe is Clevo # PB70EF. First time Clevo owners, and loving it so far!
    The OEM power adpater is a "Chicany A17-230P1A". Due to my setup, and not wanting the heavy brick dangling in the air, I need a replacement power brick with a longer cord (between laptop and adapter). Currently it's ~4ft, and could use 5-6ft. Any options that you're aware of?
    Spec are:
    AC Input: 100-240V ~ 3.5A, 50-60Hz
    DC Output: 19.5V = 11.8A, 230W
    Thank you!
  2. Meaker@Sager
    These cords are pretty short due to the high ampage going through them compared to smaller adapters (in this case 12 amps is a lot!).
  3. Harte
    Harte Newbie
    Thanks for your response, Meaker. I was wonder why the wall-side cord was abnormally long, and the laptop-side shorter than normal. So I'm guessing nothing is available on the market for these in a longer length, even with a thicker gauge cord?
  4. Prostar Computer
    There are always "universal" alternatives, but you can never be too sure about them. There's nothing specifically designed to replace the OEM adapter that I'm aware of, let alone a more premium adapter (thicker gauge).
  5. Meaker@Sager
    Short of modifying an existing brick I don't think so.
  6. Harte
    Harte Newbie
    Ok, thank you both
  7. Support.3@XOTIC PC
    Support.3@XOTIC PC Company Representative
    I just used an extension cord with mine.
  8. Harte
    Harte Newbie
    An extension cord wont help my issue since it's cord between the laptop and the ac adapter that's too short. While laying in bed, for instance, the heavy power brick dangles off the side of the bed a few inches off the ground. I'm concerned that'll eventually damage the power port on the laptop.
  9. Meaker@Sager
    A longer cord the other end would let you rest the brick on the bed. So long as it's on top of the sheets and uncovered it should be safe.
  10. Chastity
    Agreed.
