Long term users of Lenovo IdeaPad 700-15: How durable is it?
Discussion in 'Lenovo' started by DONDUS, Jun 19, 2017.
  1. DONDUS
    DONDUS Newbie
  2. don_svetlio
    don_svetlio Notebook Virtuoso
    If you keep the machine clean internally, heat shouldn't be an issue. As for build durability, you get what you pay for - if you take care of it, should last as long as any other mainstream machine.
  3. DONDUS
    DONDUS Newbie
    Thanks for your reply!
    It seems to me that overheating is a somewhat regular issue (according to various threads on the net) with this model. It doesnt bother me that much in the moment, but if it speeds up the wear and tear of the machine it's a damn shame.
    Do you have an IdeaPad 700? What are your experiences with it?
    Thanks
    //Jonathan
  4. don_svetlio
    LM did a stress test and the machine managed to hold baseclock, albeit with high CPU temps. GPU temps were very good.
    Overall, under gaming load it will be perfectly fine.
