Long battery life thinkpad
Discussion in 'What Notebook Should I Buy?' started by baii, Jan 12, 2018.
  1. baii
    baii Sone
    Going back to school in September, looking for a "cheap" lightweight thinkad with battery life.
    START COPY
    General Questions
    1) What is your budget?
    ~700
    b. Ultraportable; 11" - 12" screen
    c. Thin and Light; 13" - 14" screen
    before september
    Thinkpad only, unless dell, hp or Toshiba can make something that match point stick in 2018
    Yes. ebay, or even parts with broken display are fine.
    school
    eveywhere
    no
    more the better
    no
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    any
    Screen Specifics
    1080p min, if it can be diy upgraded, any is fine.
    Build Quality and Design
    no
    before sept
    depend on price
    Notebook Components
    will upgrade aftermarket
    no
    END COPY
    Please state any additional features you need. It's also helpful if you can indicate how experienced you are with computers. If you're a novice and don't know much, that's alright. Everyone's a novice at some point.
    Will happily diy upgrade everything if price is right~
  2. don_svetlio
    Check Lenovo's Outlet for a refurbished L/X/T series model.
  3. pepper_john
    pepper_john Notebook Deity
    I would consider a Thinkpad T460s.
  4. ZaZ
    The ThinkPad 13 might be worth a look.
