Liquid Metal repaste guide/service request, Razer Blade 15 advanced
Discussion in 'Razer' started by Makyura, May 17, 2020.
  1. Makyura
    Makyura Notebook Consultant
    Hello everyone,
    I'll go straight to the point: I've always been sh*tting my pants while thinking about using liquid metal.
    I have read far too many horror stories from people who tried applying it without enough knowledge and zero experience, turning 3k notebooks into door holders.
    I'm a proud owner of a Razer Blade mid 2019, i7 9750 (P/L Th unlocked) RTX 2080 (100W vBios), 32 GB RAM with XMP enabled, 2 TB Intel Optane 660p but thanks to the already mentioned mods, it's running too hot.
    I've seen as much material as I could about LM, but there's just too many ways how people are "ducting" transistors and other close-to-C/GPU parts, too many ways how people are applying the Conductnaut and such, mostly based on the different form factors of the notebooks.
    Does anyone of you have enough "material" to be able to make a real guide at that regard which I could study and then follow to avoid turning my precious in a dead aluminium brick?
    I'm not unfamilaird with repasting or, in general, handling cooling parts (i've been owning a custom water cooled system since 2010), so I don't need a guide for dummies, just a proper list of important things to check while proceding.
    (Other than that, if anyone reading this feels confident enough and is living in Germany or Italy and is willing to do a professional job on this, I'd be happy to reach you in person and pay for the service. Just message me or leave a commet down here.)
    Kind regards,
  2. Muezick
    Muezick Notebook Consultant
    Yeah the answer is: Don't do it.
    The more detailed answer is: ESPECIALLY don't do it if it isn't throttling.
    Even if you do everything perfectly, you will still destroy your heat sink, slowly and painfully over time.
  3. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    I’ve had liquid metal on my RBP 2017 edition for almost 3 years now. It works amazing as the day I applied it. Just don’t be sloppy with application, and a little bit goes a long way.
    Papusan likes this.
  4. Makyura
    The point is that, it does throttle a bit.
    Cleaning DEEPLY the fans has helped a damn lot, but I'm afraid that the summer will be tough.
    The heat sink problem doesn't seem to be happening with copper one to be honest, every owner of RB I've read about was really happy with LM, to say the least.
    Nonetheless, thanks for your input.
  5. Angrybot
    Angrybot Notebook Enthusiast
    Have you tried repasting with normal paste? Obviously not as good as LM, but it would be a good place to start given your (not unreasonable) hesitance over using liquid metal.
  6. Makyura
    Repasting every 3 month with Kryonaut. :)
  7. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Just apply liquid metal and forget the rest. Nothing even compares to how amazing liquid metal does. follow guides on youtube there are plenty, just be careful.
    Papusan likes this.
  8. Joikansai
    Joikansai Notebook Deity
    I live in Germany but I’m not professional repasted, just open it and repaste with good compound not kryonaut I would recommend ic diamond, that things still hold well on my 2013 Razer tablet repasted it I think in 2016, 4 years!! On blade 15 I just repasted with buddy unknown thermal paste, it just work and reduce like at least 5 degrees max load. I’d avoid liquid metal because idk LoL:D Never did it and saw users with bad result, the vapor chamber is nickel mix aluminum apparently and according google it’s not great.
