Liquid metal repaste 2 months ago - temps really high
Discussion in '2015+ Alienware 13 / 15 / 17' started by LaptopGamingGeek, Dec 7, 2018.
  1. LaptopGamingGeek
    LaptopGamingGeek Notebook Guru
    Hi all,
    I repasted my laptop a couple of months ago - and now the temps are really high again.
    I'm guessing I need to do it again, but any ideas what I did wrong that it didn't last?
    Thanks!!
  2. cruisin5268d
    cruisin5268d Notebook Evangelist
    I don’t have special powers to see what you did last time and how much material you applied
  3. LaptopGamingGeek
    Lol of course, but in your experience do you think it could be because I didn't put enough on?
    Thanks
  4. PandahNZ
    PandahNZ Notebook Consultant
    Which cores are hot? Have you had a read through the repaste guide by iunlock? Lots of good stuff in there.
    Sent from my SM-G925I using Tapatalk
    LaptopGamingGeek likes this.
  5. cruisin5268d
    It could be. Could also be the heatsink isn’t level so not getting full contact with all cores.
    Really need to see some data.
    LaptopGamingGeek and PandahNZ like this.
  6. LaptopGamingGeek
    core 0,1,2. I'll have to have another go I think. Triple check the heatsink is level..
  7. cruisin5268d
    Check your pads to see if they all have about the same level of indentation on them. If not that’s good evidence your pads are causing the issue
  8. LaptopGamingGeek
    Hmmm fair enough. I didn't change the thermal pads in fairness...
  9. LaptopGamingGeek
    well I repasted today, it basically looked like it completely dissolved...
    Any ideas based on that what I did wrong last time?
    Thanks all!
    c69k likes this.
  10. c69k
    c69k Notebook Deity
    @LaptopGamingGeek
    It looks to me that (if 2 months ago it was 1st time LM applied) part of LM has reacted with copper and lost its volume a bit.
    During 2nd time LM application I leave the stain on copper, only smooth it, not remove. Now your LM should last much longer.:) as the copper stain has the proper mix inside.
