Liquid Metal Explained: How it works, why it fails (and how to use it)
Discussion in 'Hardware Components and Aftermarket Upgrades' started by margroloc, Sep 27, 2017.
  1. Falkentyne
    Falkentyne Notebook Prophet
    GPU's have a bigger surface area so heat transfer off a heatsink is more effective than off a tiny BGA or LGA CPU with an IHS, even if the GPU is using more wattage overall (over my head here, but its clearly using less volts but more amps).
    But Pascal needs all the help it can get, with its unavoidable temp throttling.
    jaybee83 likes this.
  2. jaybee83
    jaybee83 Biotech-Doc
    yes thats true. pascal is different in that it just turbos all the way up until it hits thermal limits (at least in most systems, especially laptops, ull hit the thermal limit way sooner than the absolute max clock limit)
  3. Papusan
    What Xtreme temps? Nothing will be more extreme than 100C from the Coffee lake BGA in the new Alienware's. Aka Boiling temp.[​IMG]Mind you, You can't use Liquid metal below 10C or in subzero temps, if this is what you meant with Xtreme temps.
    Another way to remove Liquid metal.
    This one work very good as well. Indigo Xtreme Clean ™ thermal surface cleaner. Will continue to remove even more dirt after you finished cleaning up with 99% isopropanol. Data sheet indigo-xtreme Cleaner/page-dea.pdf
    And I haven't problem with removing +1.5 years old Liquid metal...
    OEM*s put more attention on the GPU cooling. They look all too much on Intel's stated 45W TDP for mobile BGA. Or better say, not more space for proper cpu cooling in todays thinner and more flimsy laptop chassis after puting a good enough heatsink/cooling for the graphics.
  4. Mobius 1
  5. jaybee83
    yep, its like der8auer is playing around with stuff ten gens ahead of us while were super happy with our sticks and stones :D
  6. Kana Chan
    Kana Chan Notebook Consultant
