Liquid Metal Explained: How it works, why it fails (and how to use it)
Discussion in 'Hardware Components and Aftermarket Upgrades' started by margroloc, Sep 27, 2017.
  1. yrekabakery
    yrekabakery Notebook Virtuoso
    I needed sandpaper to get the dried super glue off. Silicone is easy, just use a credit card or your finger nail.
    woodzstack and jaybee83 like this.
  2. oSChakal
    oSChakal Notebook Consultant
    Well, it's official, laptop just left today so @woodzstack can take care of it and fix Eurocom's mess.
    He said he would hook me up with those cooper IHS and repad with grizzly thermal pad/LM on CPU and he'll see if the heatsink make contact enough to also put LM on GPU.
    The price is more than fair and after seeing the job he did on @NIGHTMARE laptop, I know the machine will run like a charm.
    woodzstack, jaybee83 and NIGHTMARE like this.
  3. NIGHTMARE
    NIGHTMARE Notebook Evangelist
    Just give @woodzstack enough time to do the job, so he will do the testing and check anything you wanted. You can ping him on his discord channel.
    Sent from my iPhone using Tapatalk Pro
    woodzstack and oSChakal like this.
  4. woodzstack
    woodzstack Alezka Computers , Official Clevo reseller.
    Discord: https://discord.gg/K3tNGa
    Or PM me here ion NBR
  5. woodzstack
    yeah but sand paper is rough and scratches the CPU , on the IHS no prob who cares.
    jaybee83 likes this.
  6. yrekabakery
    As long as you use fine sandpaper (1000 and 2000 grit) and be careful it should be fine. I went from this to this and my CPU still works just fine. There was no other way I could find to get the hardened super glue off the PCB.
    woodzstack likes this.
  7. jaybee83
    jaybee83 Biotech-Doc
    thats definitely something to watch out for when considering superglue...
    Sent from my Xiaomi Mi Max 2 (Oxygen) using Tapatalk
  8. woodzstack
    oh snap, very well done !
    However, it would have been nice if you didn't HAVE to have done that to begin with, correct ?
  9. Falkentyne
    Falkentyne Notebook Prophet
    3000 grit sandpaper works extremely well for cleaning any hardened material off a CPU silicon slug.
    Just make sure you wet the sandpaper with 91% or better alcohol first. This enhances the polishing ability and helps reduce the abrasion ability. 3000 grit sandpaper is also very nice to have for cleaning dried or absorbed liquid metal from copper or other (non-aluminum) surfaces.
    Hardened superglue? I don't use that crap. Real men use THIS:
    https://www.amazon.com/gp/product/B...fl_title_10?ie=UTF8&psc=1&smid=A3OSNZBUPOJ7AE
    And use CELLULOSE BASED nail polish for insulating little tiny SMD resistors and caps around CPU and GPU slugs.
  10. NIGHTMARE
    Its more stronger than super glue so it will be more difficult to remove too ?
