Linux Tips and Tweaks and Other Help
Discussion in 'Linux Compatibility and Software' started by Mr. Fox, Jul 15, 2020.
  1. Mr. Fox
    I haven't ever been able to get excited about virtualization. I have tinkered with it off and on over the years, and haven't experienced any difficulties with it. I can certainly see where it is very useful for certain purposes. It just isn't useful or interesting to me.
    TheDantee likes this.
  2. jclausius
    jclausius Notebook Virtuoso
    My way around this has been to create a small library of shell scripts. I take them / modify them to fit the environment. Then when I run something like :
    ~/scripts/show_dns.sh or ~/scripts/restart_desktop.sh
    I don't need to necessarily recall if there's something specifict to each distro... I just know my script that is used to execute a certain task translates from system from system after I've had to make an adjustment to a certain distro only command.
    Vasudev and Mr. Fox like this.
  3. Mr. Fox
    Yes, that is a great idea and I have done something similar. I have a simple text document that I save on a data drive shared between Windows and Linux and I keep adding things to it so I do not have to remember or look through my bookmarked internet shortcuts to find the information. That way when I am setting up a new Linux installation I simply access that text file and copy/paste into a Linux terminal and keep going. I am starting to remember things as I refer to it as a cheat sheet and I expect that I will eventually seldom need to use it as a reference.
    This is all fantastic discussion. It probably belongs in another thread since it is off topic. My bad for getting it off track.
    jclausius likes this.
  4. Mr. Fox
    Moderators - I don't see a good Linux thread for this type of discussion. Would it be possible to put everything from post #2994 forward into this new thread, and then pin the thread? I will change the content of post #2994 after it is moved to make it a suitable thread-starter.
    Thanks! Have a nice Friday and a good weekend.
    Edit: Thanks for the help!
    Vasudev and jclausius like this.
  5. Mr. Fox
    I am the lazy type and like Linux Mint because it looks nice, doesn't require a lot of effort, and generally just works well overall. Plus, I am looking for Linux to replace Windows 10. I have been playing with Linux for 15+ years mostly as a novelty, but only recently getting serious about it because Windows 10 is such a pile of crap. So, while I am not new to Linux, I am still somewhat of a noob in terms of being a useful source of information for others.
    There are plenty of Linux experts hanging out around here. @ALLurGroceries seems to be overflowing with Linux knowledge.
  6. Mr. Fox
    All of that is old information and from what I can tell all of this support should already be included in the latest Linux kernel. Also, everything I have read (including the links you posted) circles around getting audio working on a system with no audio. I have audio and always have. The issue is I only have stereo output. The center, rear and subwoofer channels are functional and my 5.1 audio works in Windows. I only have front left and front right channel output in any Linux distro that I have installed. At this point I have simply decided I should be grateful that I have functional audio and don't really have any expectation that Linux will support my system's 5.1 audio feature set. I wish it did. It would be nice if it did. Unless it starts working someday, I guess I will have to use Windows if I want to enjoy using the additional speakers.
    I also located this information: https://forum.manjaro.org/t/sound-blaster-ae-5-5-1-surround-even-possible/113841/11
    https://forums.linuxmint.com/viewto...xt=we can try:-,1.,Surround 5.1 (or similar.)
    What is odd is if I run a speaker test, each channel passes the test and works correctly, but all of the channels are merged as mono (actually not even stereo as I thought) when I look at the output.
    If I try configuring alsamixer for multichannel I get an "Unable to find simple control" error. I have tried numerous commands and the end result is always the same.
    Vasudev, jclausius and TheDantee like this.
  7. TheDantee
    TheDantee Notebook Evangelist
    Did you try with pulseaudio installed?
    Mr. Fox likes this.
  8. Mr. Fox
    Yes, same problem. Although it is stereo (not mono as posted above). I also have the latest libasound2-plugins-extra installed, but 5.1 output is not listed. On HDMI NVIDIA HD Audio it is listed, but not for the sound card.
    Edit: It seems like maybe it is just inadequate Linux driver support from Creative.
    Otherwise, it should work just like the NVIDIA HD Audio would appear to work.
    Vasudev and TheDantee like this.
  9. Mr. Fox
    I also tried this, and still no dice...
    PulseAudio - Debian Wiki
    Surround sound system
    Many people have a multi-channel sound cards, but use the speakers for the two channels. PulseAudio has no default settings for surround sound support. To enable all channels, edit the file /etc/pulse/daemon.conf: uncomment default-sample-channels (ie remove the semicolon at the beginning of the line) and set it to 6 if you System 5.1 or 8, if your system is 7.1.
    # Default
    default-sample-channels = 2
    # To 5.1
    default-sample-channels = 6
    # To 7.1
    default-sample-channels = 8
    After making the changes, restart Pulseaudio.
  10. TheDantee
    I've been looking but it's not a common chip used in many motherboards mostly the Realtek ones so not a lot of love here I found this - https://www.reddit.com/r/linux_gaming/comments/aqfx9l/creative_sound_core3d_x_ae5_series_z_series/ and there's also a Linux Driver on the CreativeLabs Website for a different card u may be able to try. You can also try this - https://forums.evga.com/EVGA-Nu-Audio-Linux-Drivers-m2989187.aspx sorry I'm not able to find a perfect fix for you though.
    Mr. Fox likes this.
