Link Power Management == days long updates
Discussion in '2015+ Alienware 13 / 15 / 17' started by mc2wheels, Mar 12, 2018.
  1. mc2wheels
    mc2wheels Newbie
    This mistake cost me over a day of update hours...
    Just recently got a scratch and dent 15 R3 from the Dell outlet. Great machine, but only had a spinning drive, so I added cheap WD m.2 sata for the boot device. I did a fresh install of windows with the new drive and immediately downloaded all of the BIOS, drivers, and applications from Dell. One of them was the Intel Rapid Storage Technology Driver. I guess by default it set the "Link Power Management" to "Enabled". I really had no idea what this driver did or how to manage it. I was just trying to install every driver the machine was supposed to come with.
    I then immediately did a windows update... it took over 6 hours to finish. I thought I had a bad SSD. I had never used western digital SSDs before. I thought maybe they were just bad. I downloaded all kinds of bench marks, and ran them. They seemed a little slow, but not to far off spec. But everything was just sluggish. Boot times were ok. So I figured, maybe I had a driver incompatibility or something. I then ran another windows update... this was the "creator" update to windows 10, and it took 12 hours.
    After that, I ran more benchmarks, googled for m.2 sata incompatibilities, etc. Finally, I somewhat randomely clicked on the Intel management app in the tool tray, and happened upon the "Link Power Management" option. As soon as I disabled it and rebooted, the system immediately became snappier. The very next installation program I ran screamed. Oh my god! I can't believe how much time I wasted on this.
    Maybe all of you already know this, but I am an Alienware newbie. Anyway, just thought my story might save someone a bunch of time.
  2. judal57
    judal57 Notebook Deity
    intel rapid storage is discontinued. do you have to enable AHCI sata operation on BIOS or RAID
    Vasudev likes this.
  3. mc2wheels
    mc2wheels Newbie
    I hadn't changed it, but it was set to AHCI.... again, it was an outlet machine. Not sure why anyone changed it. If I set it back to RAID, I will have to reinstall everything again. Not sure I want to start all over again. What would be the advantage of having it set to RAID?
    Vasudev likes this.
  4. Vasudev
    Vasudev Notebook Prophet
    Really? I thought Intel Active Matrix storage was renamed to IRST.If its EOL, I'm uninstalling that driver package to save some 100MB.
    I still see driver updates for IRST.
    @mc2wheels Is it M.2 SATA or PCIe?
  5. mc2wheels
    mc2wheels Newbie
    I got sata because it was cheap.... again, I bought at the outlet. :)
    Anyway, I bit the bullet and installed with RAID ON in the bios instead. I notice no difference in the benchmarks, and I still had the same application installed by the dell driver down loader. This time I chose to turn off Link Power Management before doing any windows updates, and I had no issues this time.
    Vasudev likes this.
  6. Vasudev
    Link power mgmt allows your laptop to transition to lower cpu states and promise better battery life. I used this bat file and enabled HiDPM(Host Initiated HDD power down) and DiPM(Device Initiated power down). I chose DiPM on AC source and on battery chose the default HiDPM and DiPM.
  7. mc2wheels
    mc2wheels Newbie
    Much appreciated. I will give it a try. I am all about trying to save power.... just not during windows updates while trying to set up a new system.
    Vasudev likes this.
