Light, sturdy, gaming 13-15" laptop for student
Discussion in 'What Notebook Should I Buy?' started by marcv123, Feb 16, 2018.
  1. marcv123
    marcv123 Notebook Enthusiast
    Hi all, looking for a laptop to buy now to take to college. Will be used for some gaming, but also taking to classes and studying. Under 5lbs would be great, so anything in the 13-15" range would be good. Dedicated graphics card is a must, but does not need to be super fast.
    This is replacing a Lenovo edge2 with a NVIDIA GeForce 940M, so anything equal to or more powerful than this should be fine. Maybe something with an MX150?
    Thanks for your help!
    General Questions
    1) What is your budget?
    $1200
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15" max
    Weight is important too...ideally under 5lbs.
    USA
    Do not really care.
    no
    mid range gaming (world of warcraft, starcraft. No fps where high framerate matters.). Also, will use for college classes.
    Taking it with
    Yes, world of warcraft, starcraft, etc.
    not a big deal
    on line ok
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    Windows
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    Don't really have a preference.
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Build Quality and Design
    Prefer something looking pretty mainstream, without a ton of neon or flash.
    asap
    2-3 years
    Notebook Components
    no
  2. don_svetlio
    So, here are my suggestions for what you should opt to get
    DO NOT buy any Intel 7000U or 6000U series CPU. The 8000U series have double the cores on the i5/i7 models and a dual-core i5/i7 is a rip-off. This does not apply to HQ CPUs such as the i5 7300HQ and i7 7700HQ - these are still quad-core models.
    IPS screen - a must
    i5 8250U or Ryzen 5 2500U - 4 cores is a must. These 2 are roughly on par with each other. The i7 8550U and Ryzen 7 2700U are also good but more expensive.
    The Vega 8/10 iGPUs in the Ryzen CPUs may actually work for you since they perform about the same as a 940M(X) otherwise, 1030 or 1050/560 is what you should look for.
    SSD - makes a massive difference.
    Ones that I can think of from the top of my head are the Acer Swift 3 models, the HP Spectre X360 models, Lenovo IdeaPad 720s models. Asus also have some Vivobook N580 or S15 models but you have to make sure they have IPS displays as some of them come with crap TN screens. The Dell Inspiron 7577, while larger and heavier than the others, has better cooling and usually comes with a 1050 Ti or 1060 GPU. Lastly, the Asus ZenBook UX331 is also a very good option if you want a 14" MX150 laptop.
    Vistar Shook likes this.
  3. marcv123
    Bumping this thread for a refresh request please. I didn’t buy a laptop back in Feb but am ready to do so now. Based on the current market and new machines could someone please give me a few updated recommendations?
    Thanks very much!
