LG S1 WSXGA (WXGA+) cable
Discussion in 'LG' started by krossen, May 27, 2015.
  1. krossen
    krossen Newbie
    Hi,
    I'm looking for the cable (new or used) for LG S1. I've got new LP154W02 LCD screen, but unfortunately I've got only XGA cable.
    Is it still possible to get this cable?
  2. Convel
    Convel Notebook Evangelist
    You have the CCFL (backlight) cable, but not the 30-pin, 2-channel, 6-bit LVDS (video) cable? Why don't you get a generic one?
    http://www.ebay.com/itm/180954692164
    Note: Only a quick search was performed and I have neither device-specific nor pinout knowledge.
  3. krossen
    krossen Newbie
    Hi, thanks for your reply.
    Original cabel loks like this one:
    http://www.oferrovelho.com/notebook...s-dual-lvds-lcd-cable-6851b09275a-p-2373.html
    Cable from your link have the same 30-pin plug to the lcd screen, but the problem is with plug to inverter and motherbord, isn't it?
    The orignal XGA cable has P/N: 6851B09275A. I found info that cable 6851B09276A should be ok, but I'm not 100% sure that it will be works correctly. End this price ....30EUR .... for example here:
    http://www.spareslg.com/cable-assem...__store=spareslg_uk&___from_store=spareslg_pt.
  4. Convel
  5. shayh
    shayh Newbie
    Dear Krossen,
    I'm facing same issue, can't tell which cable is needed for the WSXGA LCD to work on my LG S1 Express.
    Have you succeed with solving this enigma?
    Would appreciate your kindness
    Best regards
    Shay
