LG Gram 14 MicroSD Problems
Discussion in 'LG' started by Ciclista, Aug 23, 2021.
  1. Ciclista
    Ciclista Notebook Enthusiast
    Last time I used my MicroSD card with out any problem since "not change" it just stop to works. No idea why..
    What I did to try solved?
    • Un-install drivers
    • Restart
    • Restart drivers
    • Try to change USB sleep power (is not available)
    • Restart Windows
    • Get drivers from LG
    • Get drivers from Intel
    • Tested with 2 sd cards (both working )
    https://ibb.co/6NcfJZL
    Some information:
    • Microsoft
    • 21/06/2006
    • Driver version: 10.0.19041.488
    Any idea?
  2. Ciclista
    Update: Problem solved
    Not sure what solve the issue.
  3. ZaZ
    Sometimes you get lucky.
