LG E500 SmartCam not working
Discussion in 'LG' started by ants0001, Aug 27, 2007.
  1. ants0001
    ants0001 Newbie
    Hi
    I have recently purchased the LG E500 SB11A and have found that the webcam (SmartCam) has stopped working. I have can not find it anywhere in device manager. I have also gone to the full length of rebuilding my laptop with the LG Vista CD.
    Does anyone have any idea how to get the webcam working? When I use MSN or anything else it just tells me that there is no device installed.
    Thanks for your help...
  2. tomtomtomtom
    tomtomtomtom Newbie
    I had the same exact problem with the LG E500 SmartCam and it almost drove me mad.
    In the end, just by hitting Fn+F10 you can activate the smartcam again. The thing is, when you deactivate it from there, it truly disappears from the device manager, and everywhere else.
    I just couldnt belive when that crap did the trick.
    Anyway, if that doesnt solve it, I have heard of others with the same problem that by formatting :confused: and reinstalling vista or even better XP they got their problem solved.
    Hope I was of any help.
    Cheerrss
  3. ants0001
    ants0001 Newbie
    Thanks - that is perfect. Problem solved.
  4. leks
    leks Newbie
    thanks a lot!
  5. Big Ray
    Big Ray Newbie
    yeah great thx alot
  6. klasprod
    klasprod Newbie
    hi, pls, i need help with my webcam E500 LG. it just isnt working. well, it worked once before but now it just stopped. I've tried the above options but no luck. Any help will be appreciated.
    Thanks
  7. Sadie48
    Sadie48 Notebook Guru
    I had same problem too...ended up buying new. Good Luck.
  8. locoserenata
    locoserenata Newbie
    It also worked for me! when you press fn + f10 a small icon with a camera appears alternatively with and without a red cross, indicating that the camera is on or off. What I dont understand is why this is not depicted in the manual. To whom posted the solution, did you find it by chance?
  9. Zammy
    Zammy Notebook Enthusiast
    Hey guys, I am thinking abt buyin LG R500 or LG E500. Ive noticed that LG R500 has max 2GB memory so I decided to buy E500. All of you ppl using E500 can give a view abt working of this laptop, screen, ( lol exlcuding webcam issue as ive gone through reading above posts and ill try to remember this hint).....
    Being a user, u can give the best review so please tell me abt it
    Thanks
  10. eramart
    eramart Newbie
    If nothing works, try this method.
