Let's figure out how to convert internal MXM connector an external PCI-E x16 box
Discussion in 'e-GPU (External Graphics) Discussion' started by toshiki, Aug 9, 2009.
  1. Stark03
    Stark03 Newbie
    Has anyone got any recent progress updates regarding the "adaptor" I happen to be local in Australia if you could send out a spare board... I also, conveniently have an alien ware 17r1 that needs a GPU refresh. @ShadowsNight
  2. oni222
    oni222 Notebook Deity
    I have to say this idea is great and if you need an Alienware M18 R3 to test then im down.
    I also have a titan X sitting here that I could do some testing on.
  3. sicily428
    sicily428 Donuts!! :)
  4. oni222
  5. sicily428
    You need optimus or an edp panel for new pascal cards
  6. ShadowsNight
    ShadowsNight Notebook Enthusiast
    I hope so, this is the whole reason I started this crazy crusade :p
    This is probably the case, at least using your internal display, my current test laptop does not have a screen and works with and without Optimus enabled. I'm hoping to have my end product have the ability to have the display work plugged into the desktop GPU, but it's looking like it will end up as an accessory. Since the cost would be too high for a standard kit and most people have the option of Optimus and wont mind the small performance drop. and those that do have a problem can afford the accessory.
    Good news I'm still moving house but I have a work space! I currently have Alienware M18x R1, M17x (not sure the revision, I can't remember and need to boot it to check, service tag has rubbed off), and 2 Alienware 17 R1's, I'm doing all my initial testing with the 17's because if I fry one I still have another. I'm still chasing stable pci-e speeds faster than 2.5gt/s, I've had 8gt/s with 4 lanes but it was unstable with the boards I was using.
    Edit: On the production side, I've been talking to a company that makes enterprise cables and connectors, and it looks like it will cost me $4700 AUD to set up production with them plus the units, but they have the highest cable density with the guarantee of all x16 pci-e lanes at 8gt/s and will test the unit at the factory and give me the spec sheets of what they are capable of, might even be able to get pci-e 4.0 if they don't change the MXM port :)
  7. Stark03
    Stark03 Newbie
    If we were to use the adapter would we still need an external power supply? If you need a website to sell the adapter I would suggest banggood.com as they already sell mpcie to x16 docks that have been reviewed by a variety of people. Another question, how much would one of these adapters cost the consumer without gpu or power supply?
  8. Skyl3r
    Skyl3r Notebook Enthusiast
    @ShadowsNight, do you have a list of pin pairings you're going off of that was successful?
    I'm looking to do something similar but go the other way and it'd be great if I didn't have to start from the ground up :)
  9. ShadowsNight
    Alright since it seems like life doesn't want me to finish this project here are the pins I used XD
    Looking at my notes (which are all rather sketchy) I used all the PEX pins and the SMB pins, shorting the ones that needed to be tied to ground.
    I am not saying this will work, it's been a while since I've had the time for this project and my notes are very vague, and I may be missing some.... I guess I figured I'd remember it all.
