Lenovo Legion 5/5 Pro/7 2021 Discussion
Discussion in 'Lenovo' started by saturnotaku, May 21, 2021.
  1. Atma
    Atma Notebook Deity
    What?! I still have first place?! :D
    MagillaGorilla likes this.
  2. Atma
    Atma Notebook Deity
    If anyone would like the stock paste in a sheet format you can just cut and lay on the cpu and gpu you can get it here. Same place I ordered the paste. https://www.ebuy7.com/item/651662476286 The paste, from what I can understand, has to cool at ambient temperature for 15 hours before putting on the heat sink.
    saturnotaku likes this.
  3. ringoffire
    ringoffire Notebook Enthusiast
    I think we all just need to marvel at this performance coming out of a 5.5lb BGA laptop. You are 60 points from the 11900K desktop 9lb Clevo record. This TDP was not possible in a laptop this size even two years ago.
    MagillaGorilla and Atma like this.
  4. MagillaGorilla
    MagillaGorilla Notebook Consultant
    Watch me beat it ;)
    Again, love this machine
    But, this is the score I’m chasing:
    https://www.3dmark.com/spy/20531317
    It’s the damn MSI 165w continuous TGP that’s killing me. That, or he/she’s shunt modded
  5. Papusan
  6. MagillaGorilla
    Oooof
    I see some chilling/extra cooling involved, and maybe even shunt mod. That or the temps are allowing it to sustain.. Either way, Nice!!
    I won’t be shunting, and already at the 11980hk’s limit.
    Still prefer the 7i’s footprint tho ;)
  7. Spring1898
    Spring1898 Notebook Consultant
    So I have pulled apart both a Legion 5 Pro and a Legion 7 (AMD versions) and I am pretty sure both are effectively the same motherboard, with only daughter board changes to account for different ports, color of the PCB, and some minor component changes (for example the ribbon cable connection for the light bar is absent on Legion 5 Pro).
    This makes sense to me as it would be less R&D and better economy of scale for Lenovo, as the core specifications of the chassis can be the same between models.
    In theory one could make a 3080 vapor chamber Legion 5 Pro by swapping the motherboards and the cooling solution. Lenovo also could have made this, but I suspect they knew it would cut into the sales of the Legion 7 to get a 3080 variant a bit cheaper without the aesthetic upgrades (which mean nothing to me, but perhaps for other people).
    EDIT: There is just enough difference in the chassis to prevent a direct swap. The screws for the fans which connect to the hinge location are in slightly different locations. If you ground off the alignment studs it would probably work.
    Keyboard on Legion 7 is pretty bad for me. There is almost no key travel. The keyboard on my ipad and my thin and light has more travel than the Legion 7's. Also not all the keys are the same height, and because there is so little travel it can be evident on closer inspection. It is also noisier with less consistent noises across the keys compared to the Legion 5 Pro likely for the same reason. Instead of the typical dull thud of the Legion 5 Pro keys, it is a much more audible tap as the key bottoms out on the chassis.
    Also because the keyboard color matches the chassis finish, and the letters are white, in certain lighting it is almost impossible to see the lettering on the keys without back light, whereas the contrast of the black keyboard of the Legion 5 Pro prevents this.
    I don't really understand this design choice. It may have made the laptop a hair thinner than the Legion 5 Pro, but the loss of the extra 1/2mm of key travel was not worth it on a laptop this heavy. The legion 5 pro keyboard is far superior for a typing experience unless you are a very light and lithe tapper of the keys.
    The Laptop is overall thinner than the 5 Pro (probably same as non pro) but again this is not noticeable because of weight and size. The rest of the dimensions are also smaller slightly but only due to the design choices of the 5 pro aesthetic.
    The sound is supposed to be better on the Legion 7 with notably larger speakers (almost twice the area), and more audio customization, but in practice I think this is lost because they face STRAIGHT DOWN, where all other models have at least angled speaker ports to direct the sound out. This had to be done because of the light bar took up too much of the chamfer to fit the speaker properly. So they sacrificed sound quality for lighting. Now I realize that speakers on a laptop aren't that great anyway.
    Overall, unless you need the 3080 and the 5900hx or top Intel chip, or really want the aesthetics, or a lid that can fold down all the way flat, I think the Legion 5 pro is the better buy and nicer machine.
    One last thing I forgot to mention is that the Thermal Paste on the Legion 7 seems different from that on the Legion 5 Pro. It was not dried out, and appeared to have silver metal embedded into it. I discovered it when I pulled off the vapor chamber, and tried to clean off the paste with alcohol. It did not dissolve well and left a silver metal behind (this is not liquid metal), which had to be scraped off with a spudger. So I think you should leave the vapor chamber and thermal paste alone on this unit.
  8. Kalen
    Kalen Notebook Consultant
    I disagree completely. The Legion 5 Pro is quite a bit thicker than the 7 (I had both and sold the Legion 5 Pro). I personally hate the aesthetics of 5 Pro and the contrasting keys are part of it; makes it feel cheaper and the flex of the deck while typing illustrates this. Additionally, the plastic deck is a different grey than the aluminum top and bottom; add in the dark grey venting and there are just too many different colours everywhere. I don't think it will age well in design.
    I prefer the typing experience on the 7 (and most reviewers do too including Jarrod's Tech ). I've never had any issues of difficulty seeing the keys either.
    The 7 is just a better build all round.
    Sent from my SM-G970W using Tapatalk
  9. Spring1898
    The difference in height between the two units is only about 2mm at its max point when they are both on the table. This is due to the curvature of the Legion 5 Lid. So if that is much thicker to someone so be it. I think it gets washed away with the rest of the size of the machine, and Jarrod mentions the same. The Legion 7 is slightly smaller footprint because the plastics of the Legion 5 Pro stick out more.
    As far as the colors of the Legion 5 Pro, there are actually only 2. The gray aluminum finish, which is slightly darker than the Legion 7's, and the dark plastic of the keyboard and vents and the bottom plate being black. If you wish to count the bottom being a different color because it is aluminum vs plastic then it could be 3 colors.
    The Legion 7 also has 2 (or again 3 depending on how you look at it), but it is much more hidden. The lighter gray aluminum, (slightly different shade on the plastic keys of course), and the rear grill which is black plastic.
    So it sounds like what you are saying is that you prefer a cleaner more uniform design overall.
    As far as the contrasting keys being distracting, this is personal preference. Many laptops use contrasting keys, or a darker finish overall, particularly on business laptops and especially apple.
    But for me it is not the contrast as much as the glare when you are unable to control the artificial light source. This is made worse by the keys being flat rather than dished. I had a similar problem on other laptops.
    My bigger issue with the keyboard is the lack of consistency between the keys and the key presses on the Legion 7. Each key on the top row presses and sounds different from the other. Flex is noticeably worse on the left side of the keyboard and virtually stops around the Return key. Does this affect my ability to type? No but it is noticeable to me and not what I would expect from a more premium build. The Legion 5 pro also suffers from this to some degree, though not nearly to the same extent.
    Most people can type better on short travel keys because you are not punished for over pressing (at least in the short term), and it is more difficult to under press on short travel keys. While there is less flex overall in the Legion 7 deck compared to the Legion 5 Pro this is largely due to the thinner keyboard and the metal top plate construction. However neither of my units has enough flex in the deck under normal typing to be noticeable. Not sure if this was Jarrod's specific unit or mine, but I do not appreciate nearly the amount of flex he demonstrates in the video on the Legion 5 Pro.
    You can hear a little about how the keys sound different in the Legion 7 in his review though, some sound like normal short travel keys, others appear to slap the deck when pressed. Mine is worse.
    Also in contrast to his video, my Legion 7 touch pad was noticeably more consistent in press pressure and registering clicks vs the Legion 5 Pro.
    The biggest thing that bothers me about my particular Legion 7 is that the screen is noticeably inferior to the Legion 5 Pro. I don't have any dead pixels that I have seen, but the contrast, sharpness, color depth, max brightness are noticeably lower on the Legion 7, even from a couple meters away. (For clarity, this is same profile, background, brightness, etc). Given that there seem to be a number of Legion laptops with the 16" screen having some issues, I think this is not surprising. I was actually thinking about swapping out the displays, but that would be a lot of work.
    With the Demand for laptops so high, it would make sense the QC is less strict, which explains the overall lack of consistency from one unit to another in the same line. You mention the build quality is superior on the Legion 7, I agree it should be, which is why I am more noticing of the small flaws and inconsistencies as the more premium build quality demands.
  10. chrischris99
    chrischris99 Newbie
    I am currently also comparing a L5P (AMD) with a L7 (Intel). I first got the L5P a week ago and really like it but I was curious to see what I was missing with the "better" L7. So I got the L7 yesterday and have two main questions:
    1) What I noticed right away, on the L7 there is a lot of play and flex at the bottom of the screen in the middle, as if something is not mounted properly there. You can also hear a strange noise when opening and closing. When the laptop is closed and you press very lightly on the back, it also bends a bit. The further you go to the hinges, the less it gets. The whole thing seems strange and not very solid. The L5P sits super tight in comparison and nothing wobbles. With the L7, I'm afraid that once the laptop is in the backpack or something similar, that something can break on the display attachment. I made a quick video showing this. https://www.reddit.com/link/pm30xi/...t&utm_name=LenovoLegion&utm_content=t3_pm30xi
    I have only pressed very little force and know that some flex is normal, but that does not feel very solid I must say and especially compared to the L5P, the display feels very wobbly from the attachment. I also have two Thinkpads (X1 Extreme / T480) and their display attachment is rock solid in comparison to the L7.
    Do you have that with your L7 too and is that normal?
    2) I have two different panels in both machines. The L7 has the CSOT T3 MNG007DA1-1 the L5P the BOE NE160QDM-NY. They are both really bright and looks quite similar. But I personally felt the CSO panel had better black levels and therefore the colors come through a bit better. But I only noticed that when watching movies.
    Which panels do you guys have in your L5P / L7? And are there any reviews or comparisons between the panels?
    3) The L5P I got came without Windows and through some researach I found out that there is a X-Rite Pantone factory color calibration coming with it. So I installed X-Rite Color Assistent and downloaded the profile from the Lenovo cloud. I did not have to enter anything and I just had the profiles in X-Rite and it looks so much better. I was curious if the downloaded profile is a specific profile just for my unique panel or like a generic calibration file for the model? I was curious because there are different panels (see my point above) and if everyone is individually calibrated at the factory?
