Lenovo Ideapad Z510 Wireless problems
Discussion in 'Networking and Wireless' started by Tiristan, Jan 16, 2014.
  1. Tiristan
    Tiristan Newbie
    Hey all,
    I bought the Lenovo Ideapad Z510 yesterday and was excited to try it out, however one thing i noticed off the bat was the poor WiFi performance on the otherwise flawless laptop. At times it becomes weak, and suddenly disconnects, leaving me with the "Limited Connectivity" sign. I did some research and found this was a widespread flaw in the Z510 which many users reported. There is no current guaranteed fix to this problem, and I was wondering if anyone here could help me and fellow Z510 users out as it's becoming very very annoying.
    Cheers.
  2. cbautis2
    cbautis2 Notebook Consultant
    What WiFi card do you have? If it's the 7260N, install the 16.8.0.6 drivers as I found it to be stable. Although it slows down presumably due to WiFi interference, it's able to return to top speeds instead of resorting to "Limited Connectivity". Go the 7260 thread to get the 16.8.0.6 drivers. Remember to use Inssider to find the best channel.
  3. Tiristan
    Tiristan Newbie
    I'm not sure which WiFi card it is, how am I able to check? I apologise for asking "noob" questions, I'm a bit of a technical rookie.
  4. cbautis2
    On Windows 8.1, open device manager by right clicking the start button then click device manager. Expand the network adapters page and you'll find your WiFi card there.
  5. Tiristan
    Tiristan Newbie
    It says Broadcom 802.11n Network Adapter...should I still get the 16.8.0.6 driver?
  6. cbautis2
  7. Tiristan
    Tiristan Newbie
    Tried those steps, didn't work.
  8. cbautis2
    If you're willing to flash a modded BIOS for your Z510, you can use a search engine to obtain that. Then buy some good WIFi cards like Intel 6300. You can also get the 7260AC and obtain 866.7 Mbps speed though it has an annoying bug that makes the 5 GHz band disappear when the 7260 cannot return to normal speeds (i.e. return to 144 Mbps or 300 Mbps) once it gets to speed drop of no return (2 - 11 Mbps). You can eliminate that by connecting to the 5 GHz band (in my case).
  9. Tiristan
    Tiristan Newbie
    That sounds really complicated and definitely out of my league...are there no drivers I can download to resolve this issue?
  10. cbautis2
    Thanks for the rep!
    Well, you can try some Broadcom WiFi drivers here and see if it helps: Station-Drivers - Broadcom (WLan)
    Download the 21/11/13 Version 6.30.223.170 (W8.1)/6.31.223.1(W8)/6.32.223.1(W7) by clicking on the floppy drive icon.
