Lenovo ideapad y410p geforce 750m SLI vs Clevo w230st and w740su
Discussion in 'What Notebook Should I Buy?' started by oljo01, Jun 23, 2013.
  1. oljo01
    oljo01 Newbie
    I'am realy dont know what laptop i want (1 of these 3) i want a small laptop for a little gaming (neverwinter nights 2, fm, skyrim) the w740su has only intlel iris pro 5200 that i like because it doesent have optimus but its a less powerfull gpu. The geforce gt 750 SLI is the most powerfull of the 2 geforce cards.
    So i realy dont know what to choose!!
  2. Bomba90
    Bomba90 Notebook Guru
    1. What about the MSI GE40 (14" 4.4 pounds)?
    2. Do you want a small size because of weight or because you prefer having a 14"-13.3"? If it's because of the weight then you can even go for the MSI GE60 as it weighs less than the Y410 (5.5 vs 5.28).
  3. oljo01
    oljo01 Newbie
    1. Never heard of it before, usualy the msi gaming laptops looks like xmas tree with all the lights ect, but this one look good.
    2. i want a small size because i have a 15" now and its to big and ofc 13" is easyer to take with me. i think i would prefer 14" insteas of 13"
    I love the Clevo discret design.
    Sorry for my bad English its not my native language.
    Sent from my GT-I8750 using Tapatalk
  4. oljo01
    oljo01 Newbie
  5. Benmaui
    Benmaui Notebook Evangelist
    You should also check out Gigabytes ultrablade p34k, alienware m14 and Razerblades new 14" .
  6. Bomba90
    You haven't said anything about the budget...
    AW m14 is super heavy 6-6.1 pounds.
  7. alexsupreme
    alexsupreme Notebook Consultant
    You will also soon have a new g46VR from asus. Although it seems too heavy for a 14"
  8. oljo01
    oljo01 Newbie
    My budget is max 1600$ but i dont want to use that, the laptops i am looking on is around 1100-1300
    i dont like alienware, i will check out the gigabyte:)
  9. Calibre41
    Calibre41 Notebook Evangelist
    The Clevo W230ST will be out soon, and tramples all over the rest with its 768 cuda core GTX 765m, also MSI have the MS-1492 which will be about $75 less than the W230ST and has a near indentical GPU called the GTX 760m.
    Alienware - quality chassis, quality customer support (not sure about reliability of the electronics) but just a ridiculous price tag and poor performance per $ and it's as big as a 15" Clevo and for the same price as the top M14X with the 765m, you can buy a Clevo with a GTX 780m........ enough said?
    same goes for the Razor Blade, it features a near useless 17w CPU which will hold back the 765m, which I also suspect will throttle due to heat and power restrictions - and it's price is enormous, again your not buying it for maximum bang per buck, same as the Alienware, stunning performance but - it is fashion, style and aesthetics and it's unique form factor that are it's selling points.
    best performance per $ = MSI MS-1492
    add a little quality and maybe a few % more performance and the CLEVO W230ST is the winner (backlit keyboard, sleeker chassis, smaller form factor)
