Lenovo edge e425 processor upgrade
Discussion in 'Lenovo' started by Trygy4, Jun 15, 2019.
  1. Trygy4
    Trygy4 Newbie
    Hey, I have the lowest spec Lenovo e425 on earth. I got it with windows xp, 2gb ram, a 5200rpm 300gb hdd and the lowest-tier processor available which crawls like a crippled slug.
    I already bought 8gb of 1600ram and an SSD and upgraded to Windows 10. Now, I want to know if it's possible to swap the processor out with something higher end? The old amd processors are a dime a dozen now, and if I can significantly increase the speed for less than a stick of ram, why not?
    If it's possible to swap out the APU, what is the fastest processor I can change it for? The best spec'd processor in the e425 owners thread was the AMD A8-3500M, so I'm assuming that is the safest bet if it's possible to swap, but would it be possible to go even faster?
  2. ZaZ
    According to the hardware maintenance manual, the CPU is replaceable.
