Legion 5 Pro Thermal Paste FYI it is dry (on my unit)
Discussion in 'Lenovo' started by Spring1898, Jun 4, 2021.
  1. Muyfa666
    Muyfa666 Notebook Evangelist
    Did you replace all pads with better brand 1mm ones?
  2. bigspin
    bigspin My Kind Of Place
    Yes. I Used Gelid extreme 1mm thickness (80mm x 40mm) pads. You need 2 of those. 3 if you're planning to change ssd pads as well. I recommend changing them too. My ssd temps drop by 8-10c with those pads.
  3. Muyfa666
    I may actually do that then. Did you make sure all the pads are connecting after changing?
  4. bigspin
    Yes. This is the correct thickness
  5. Muyfa666
    Cool. I'll go with Arctic Cooling pads thou, as those are the ones I can find locally. Still much better than stock I bet.
    EDIT: Found Gelid-Extreme now. Ordered 3x 80x40x1,0mm.
  6. IKAS V
    IKAS V Notebook Prophet
    After repasting does anyone notice any less fan noise ? Hate, hate , hate loud fans
  7. Muyfa666
    The difference is not big.
    Disable turbo if you want a big change.
  8. KING19
    KING19 Notebook Deity
    Stock paste is normally fine and you shouldnt change it if your temps are fine
    Problem with stock paste that it doesnt last long as mines is already dried out after 8 months
  9. Terreos
    Terreos Royal Guard
    Jarrod’s review shows that this laptop loves extra airflow. And the fans apparently spin slower as it runs cooler. No way to manually change it on this model. So I’d imagine a repaste and a good cooling pad will give you the best results.
    Not sure if anyone has a cooling pad to give some feedback?
    IKAS V likes this.
  10. Lovedrunken
    Lovedrunken Newbie
