Legacy AlienFX Tools and Applications
Discussion in 'Alienware Area-51/Aurora and Legacy Systems' started by findvikas, Oct 6, 2008.
  1. findvikas
    findvikas Notebook Deity
    It was you Moo.
    @bkral, I guess I found your problem.. may be. Have you chosen Desktop as option in the program? If I use Desktop then I can reproduce the problem that you told me.
    Could not test Command Center as I do not have it installed on my machine. Make sure you are choosing Laptop as an option and reset the color again
  2. The_Moo™
    The_Moo™ Here we go again.....
    at the moment i do not have my M17x but as soon as I do I will get with you to help test the M17x to get this great program working
  3. bkral
    bkral Notebook Consultant
    Im waiting for somebody to possibly get the patch for the m17x lighted keyboard. but that file is in myHive... which since this is a 2nd laptop... I cant access...
    "m17x_lighted_keyboard.zip" is the patch from myHive I need... because I remember at one point having to patch the m17x_RIPLEY_Model.exe. And by reading that I guess I must have installed the one that doesnt have the lighting registry entries. :\
  4. findvikas
    Here is the replica of the My Hive...
    http://forum.notebookreview.com/showthread.php?t=342331
  5. The_Moo™
  6. bkral
    yeah. if i use that. when i open Command Center... it says the model of laptop doesnt match the theme so settings cant be applied.
    And i dont see a setting anywhere to change from "desktop" to "laptop".
  7. ryujin
    ryujin 2B or not 2B
    you may want to PM findvikas then and see if he can assist you better.
    he has been one of our "inventors" for several programs and stuff.
    he should be able to guide you through what you need.
  8. findvikas
    You are right actually, I missed that part.
    Open the attached ZIP file and apply the patch according to your model (
    Ripley or Skullcap)
    From an old thread of mine...
  9. bkral
    yeah. i tried that last night. some of the registry entries you mention weren't actually in my registry.
    is the f17ripley registry entry for the first gen m17x?
  10. findvikas
    yes (10 chars)
