Led Keyboard w/ Backlight Controller with LightFX + Hotkey
Discussion in 'Sager and Clevo' started by Tb5..., Jul 3, 2014.
  1. Tb5...
    Tb5... Notebook Geek
    system in sig.
    decided to swap out the boring stock led software for Backlight Controller with LightFX http://clevomods.wordpress.com/custom-light-controller/ things were fine until i started putting my laptop to sleep. every wake-up, the led config would just change, so i'd have to re-establish the proper settings so not too bad.
    however now Backlight Controller with LightFX won't start up at all...
    Code:
    Problem signature:
      Problem Event Name:	CLR20r3
      Problem Signature 01:	ledkb.exe
      Problem Signature 02:	0.0.6.0
      Problem Signature 03:	5274db34
      Problem Signature 04:	LEDKB
      Problem Signature 05:	0.0.6.0
      Problem Signature 06:	5274db34
      Problem Signature 07:	ee
      Problem Signature 08:	0
      Problem Signature 09:	System.IO.FileNotFoundException
      OS Version:	6.1.7601.2.1.0.256.1
      Locale ID:	1033
      Additional Information 1:	0a9e
      Additional Information 2:	0a9e372d3b4ad19135b953a78882e789
      Additional Information 3:	0a9e
      Additional Information 4:	0a9e372d3b4ad19135b953a78882e789
    thought upgrading to Hotkey 7.0026 might fix the issue, but i'm getting a 1628 failed to complete installation error when trying to install, or uninstall Hotkey software:mad:
    :spinny: now i'm over here with a un-lit keyboard like some kind of animal...
    any help would be appreciated,
    thanks.
  2. Tb5...
    anyone?? main issues with uninstallin hotkey 6 so i can install hotkey 7
    help with this??
  3. kostas
    kostas Notebook Enthusiast
    You're missing some file.
    ok, let's take it from the beginning.
    Uninstall the backlight controller and the hotkey utility.
    reboot
    install just the hotkey utility
    reboot
    do you get color change via the stock color changer?
  4. Tb5...
    i got fedup and decided to do a re install of Win 7, i installed the Hotkey driver from the original driver CD, the lights seem to be working now.
    i wanted to upgrade it to v.7 so i then uninstalled Hotkey 6 and now when i try to install Hotekey 7 i get the same Installshield error: 1628 failed to complete installation
    i wonder what file it could be that's missing
