LED Keyboard Bug
Discussion in 'Sager and Clevo' started by squee666, Apr 23, 2018.
  1. squee666
    squee666 Notebook Evangelist
    So I cant seem to get correct colours in the software.
    Basically on a fresh install it worked now later on it doesnt.
    By default when it boots its a Deep Blue, in software I cant even get this colour anymore.
    Purple worked but now its a Better white than actual white when selected.
    selecting blue now only gives light options its like the wholeare is limited in software when it worked before.
    This happened after i reinstalled CCP after uninstalling it because I had HKB disabled and wanted it back
  2. Support.2@XOTIC PC
    What is your current model?
  3. Meaker@Sager
    Might be worth re-install the suite again.
  4. squee666
    its a P670RS-GM
    reinstalling the suite persists with the same bug.
    like i said i know it ca hit the colours i want because i had them before T_T
