LCD Monitor that can double as a TV
Discussion in 'Accessories' started by eclecticdoode, Jul 28, 2006.
  1. eclecticdoode
    eclecticdoode Notebook Consultant
    Hey, I don't know if this is possible but I am looking for an LCD monitor that can double as a TV or vice versa an LCD TV that can double as a monitor.
    I was looking at the dell 20 inch widescreen monitor but I don't know if it can be used as a TV.
    Thanks.
  2. HomeSkillet
    HomeSkillet Notebook Evangelist
    It would still need a TV-Tuner, but all the other features and connections are in place.
  3. cerebrus
    cerebrus Newbie
    What are the tradeoffs in using the same lcd monitor for TV viewing and computer use given the input ports aren't an issue?
    I'm using a Dell 23" Lcd TV monitor as aTV and as a monitor for a backup computer. The limitations for computer use are fairly obvious in the limited
    resolution. It's still fairly useable as a computer monitor, but not something
    you'd want to look at text all day. Obviously great for TV viewing.
    What I'm not clear on is the obverse ie: using a 20" or so computer monitor
    as a TV monitor. I'm using cable box as HDTV source so lack of tuner is not
    a problem. The box has a DVI output and I'm wondering what the result would
    be like on a monitor like the Gateway 2185. What's the downside of this kind of setup?
  4. mZimm
    mZimm Notebook Evangelist
    Personally, I love the idea, and I plan on getting a 24" or higher LCD monitor and simply plug in my receiver to the LCD instead of bothering with a TV tuner for my computer. I'd have a great monitor for computer use with a high resolution, and an LCD capable of HDTV resolutions. However, there would be a couple hindrances. One being that in order for this to work your cable box, sat. receiver, or whatever you're plugging in is going to have to have the same outputs as the monitor has inputs. This isn't really a downside, however, because the newer stuff has a DVI or component out (the Dell 2407FPW has component, the 2007FPW does not FYI).
    The downside would basically be the opposite of the downside of using a TV as a computer monitor, and it's going to be the same downside as if you buy a really expensive 1080p HDTV. Unless you have a 1080i or 1080p signal, it's simply not going to look that great at that high resolution. The resolution of current DVDs is 720 × 480, and when that's stretched out onto a WUXGA LCD it isn't that clear. Those of you who have WUXGA screens and watch DVDs know it's not exactly optimal, and it's the same way if you have a 50" 1080p plasma TV and you watch DVDs, so it's not restricted to computer use, it's a restriction of the DVDs. If you watch something with a 720i or 720p signal it will be the same way, just not as bad. 720p has a resolution of 1280 x 720, so it will also be a little fuzzy when stretched over that many pixels. If you are fortunate enough to have an input of 1080i or 1080p then you can watch the signal on the 1920x1200 screen at a resolution of 1920x1080. This is optimal, because with small black bars you can watch the feed in the native resolution of the screen and it will look perfect.
    The more I think about it, unless there is a downside to computer LCDs in comparison to LCD TVs (refresh rate?) there's really no reason not to go this route. It also enables you to use your computer as a DVD player or a DVD Recorder if you want, and saves money on an expensive TV and an expensive monitor.
  5. Daetlus
    Daetlus Notebook Consultant
  6. Rockmaninoff
    Rockmaninoff Notebook Enthusiast
    Gateway FPD2185W
    Samsung 215TW
    Westinghouse 22W2
    Those are all fabulous monitors with additional inputs for your composite, component, or S-Video signals. They're HD-ready, and the Samsung (which I will most likely be picking up for college) has an HDCP-compliant DVI-D input, meaning it'll work well with Vista. The Gateway's got a 4-port USB hub, as well. They feature PIP and a really fabulous picture, and are all priced around $500 right now. Look for them at Best Buy, Office Depot, or Froogle.
    Just my $0.02.
  7. DrewN
    DrewN Notebook Evangelist
    If you're using an HD cable box and feeding the signal via DVI directly into your monitor than there is no difference from the reverse -- you'll get a great picture provided your monitor supports HD resolutions. The big question for you is -- does your cable box and the 2185 support 720p (1280x720)? Because at 1680x1050 max resolution you cannot get a 1920x1080 (1080i) signal, which is what many cable companies use for HD.
  8. DrewN
    Listen to this gentleman, he speaks the truth :)
  9. eclecticdoode
    Hey guys, I just got this TV/PC monitor at Circuit City. I had a $75 gift card so that made it that much more attractive. It's great with the VGA cord and my DVD and Directv viewing is awesome too.
    Here's another link from newegg. I'm gonna stick my gamecube in later and see just what I've been missing. I've seen mario on a regular CRT for nearly 20 years now. Bout time for an upgrade.
  10. Daetlus
    This gateway is the same one I tested, wonderful monitor, just not one that I would have use for
