Latest LAN-Wireless-Bluetooth Drivers
Discussion in 'Networking and Wireless' started by Spartan@HIDevolution, Feb 4, 2019.
  1. Spartan@HIDevolution
    Latest LAN & Wireless Drivers 25-Mar-21
    Make sure to right click on the file you just downloaded, go to Properties, then hit Unblock from the bottom right as it may be blocked since it was downloaded from the internet, if you don't do this before you extract it, then it may not install correctly.
    To prevent this automatic blocking of files in the future so you don't have to go unblocking every file you download to ensure it runs properly, follow the guide in this thread:
    http://forum.notebookreview.com/threads/are-you-sure-you-want-to-run-this-file-yes-or-no.825668/
    Killer E2X Ethernet Driver v9.0.0.50
    Killer E2K Ethernet Driver v10.043.0723.2020
    Killer E3000 Driver v10.043.0723.2020
    Killer E3100 Ethernet Driver v1.0.2.6
    Killer 1550/1650/Intel WLAN Drivers v22.40.0
    Killer 1202 WLAN Driver v10.0.0.355
    Killer 1435-1535 WLAN Driver v12.0.0.953
    Killer 1525 WLAN Driver v12.0.0.448
    Killer 1550/1650/Intel Wireless Bluetooth Driver v22.40.0
    Killer 1435-1525-1535 Bluetooth Driver v10.0.0.916
    Realtek LAN Driver v10.46.1231.2020
    Realtek USB GBE Driver v10.39.20.0518
    jc_denton, Vasudev and Papusan like this.
  2. Spartan@HIDevolution
    Latest LAN & Wireless Drivers 31-Mar-21
    Realtek LAN Driver v10.047.0121.2021
    Realtek USB GBE Driver v10.43.20.1029
    jc_denton, Papusan and Vasudev like this.
  3. Papusan
    Papusan Jokebook's Sucks! Dont waste your $$$ on FILTHY
    Intel have now posted download links for latest Wireless drivers March 30, 2021
    https://downloadcenter.intel.com/product/59485/Wireless
    Wi-Fi (WLAN) 22.40.0
    • A mobile device and the PC create a multi-screen connection on the wrong frequency band (e.g. 2.4 GHz).
    • Windows Stop Error (BSOD) due to a stack overflow error.
    • 802.11g power throughput may decrease and not return to normal if received signal strength fluctuates.
    • The network connection can break off shortly after a mobile hotspot connection is established with the PC.
    • Windows Stop Errors (BSOD) related to the Intel Wireless Driver can occur.
    • The Intel PROSet / Wireless Software 22.40.0 has been updated to include functional and security updates. Users should update to the latest version.
    Bluetooth driver 22.40.0
    • Starting with driver 22.40.0, Intel has updated the following products from Bluetooth 5.1 to Bluetooth 5.2: Intel Wi-Fi 6 AX200, Intel Wi-Fi 6 AX201 (Note: This upgrade does not introduce any new features. It does, however, implement corrections such as the Bluetooth 5.2 specification).
    • When a video is playing after a Skype call, sound may be disrupted on some systems.
    • The Intel Wireless Bluetooth 22.40.0 driver has been updated to include feature and security updates. Users should update to the latest version.
  4. Spartan@HIDevolution
    Updated the link above with the EXE installer of the Bluetooth Driver as the previous INF one was tricky to install.
  5. Jdpurvis
    Jdpurvis Notebook Evangelist
    So far, so good - initially, they clobbered my APTX driver (BT), but a re-installation of the special CSR driver and a reboot brought it back. All good here.
  6. Spartan@HIDevolution
    deleted driver
    Vasudev, Jdpurvis and Papusan like this.
  7. Jdpurvis
    Works for me - both Killer 1650 and Intel cards seem fine with it. :)
  8. Spartan@HIDevolution
    Intel bought Killer, they are the exact same cards, same drivers, just different firmware (the Killer auto downloads the Killer crap)
    Papusan, Vasudev and Aivxtla like this.
  9. Jdpurvis
    I know - that's why I never go to the Killer site. Because they are the same card, they should behave the same - but not everyone knows they are identical. :)
    Vasudev and Spartan@HIDevolution like this.
  10. Spartan@HIDevolution
    Latest LAN & Wireless Drivers 14-May-21
    Aquantia AQtion LAN Driver v2.2.3.0
    Killer E2K Ethernet Driver v10.047.0121.2021
    Killer E3000 Driver v10.047.0121.2021
    Killer E3100 Ethernet Driver v1.0.2.13
    Killer 1550/1650/Intel WLAN Drivers v22.50.0
    Realtek LAN Driver v10.48.315.2021
    Realtek USB GBE Driver v10.45.20
