Laptopvideo2go driver problems
Discussion in 'Gaming (Software and Graphics Cards)' started by Tomas, Aug 1, 2005.
  1. Tomas
    Tomas Notebook Consultant
    HUh...weird, because even before i was overclocking, i was getting temps as high as what i'm getting now. It never goes higher.
  2. LuckMC11
    LuckMC11 Computer Extraoirdinaire NBR Reviewer
    that is pretty wierd...maybe because my laptop was plugged in??..or like always on or sumthing that's y mine went 2 54 degrees...??...maybe??..and i also use CHC (Centrino Hardware Control) 2...im not sure if that keeps it cooler or not though...and i don't have a laptop cooler...yet :p :confused: :eek: :D
  3. Tomas
    I ordered a Vantec lapcool2 just the other day to keep the heat down. As far as CHC goes, unless Dell put it in there, I don't think i'm using it. I'm not too worried about 62c because i've had my 9300 since March and it never has been a problem before. Besides, it never gets above that no matter how long I am gaming. I only got the cooler as a "just in case" backup. I keep my 9300 plugged in all the time. You think that may be part of the heat rise. Huh...if my system is usually plugged in, could I take out the battery and run straight off the AC to reduce heat? Then just replace the battery when i want to move it?
  4. LuckMC11
    i doubt that has anything to do with it :p ...lol..and for CHC..u g2 download it yourself
  5. Tomas
    o well, just thought i'd ask. Thanks for the info.
  6. LuckMC11
    no problem..can i get any rep points?? :p
  7. Tomas
    Sure, what are they for, and how i delete threads that i start, like this one?
  8. LuckMC11
    umm..welll..i don't think u can delete a thread after there is 1 post after urself...i think it can only b locked if there is more than 1 post in it..just leave it :D
  9. Tomas
    k. It just seems kinda useless to keep around now.
  10. LuckMC11
    yea...there are a lotta posts in these forums that are kinda useless...just like cross-posters..lol..no point to those :mad:
