Laptopvideo2go driver problems
Discussion in 'Gaming (Software and Graphics Cards)' started by Tomas, Aug 1, 2005.
  1. Tomas
    Tomas Notebook Consultant
    K, here's my problem. Everytime i try use any driver and modded inf from www.laptopvideo2go.com I reset my 9300 and get an error "instruction 0x00407146 something or other 0x000000008 could not be read". Sorry i couldn't catch it all, as it is only on the screen briefly. The drivers themselves seem to work alright and whenever i use drivers from DELL and Nvidia i never have any problems. Does anyone have any ideas as to what the problem may be? Thanks in advance.
  2. LuckMC11
    LuckMC11 Computer Extraoirdinaire NBR Reviewer
    which drivers are you using???
  3. Tomas
    Right now i'm using DELL's 77.24 with no problem whatsoever. I only get the error whenever i use ANY DRIVER AND MODDED INF from LV2G. The thing is though that i get higher framerates with the modded drivers and inf's, so I would like to use them. I use Extreme G drivers and don't get the error but for some reason they are kinda buggy with BF2 for me.
  4. LuckMC11
    ahh..did u try uninstalling the drivers and then reinstalling them??
  5. Tomas
    yeah, no luck. that's why i went back to 77.24. O well... i'll just use find the best driver for me at guru3d. I've never had a problem getting drivers to work there. I just hope it's not happening because of a larger problem that I can't see. I've googled the error and get nothing that matches mine, though there are others that are similar that don't sound so great. So i'll keep looking around. Other than that one error, everything else works great, so who knows?
  6. LuckMC11
    which other driver's did u try 2 install??...cuz u know...not all of them work for the 9300...ya know..and i'm using the 77.76 drivers from www.laptopvideo2go.com
  7. Tomas
    I tried 80.40 , 77.77 , 77.76 , and 77.72. I gave up before trying 77.70. Those were made just for mobile gpu's, correct? I just went back to 77.24 and downloaded coolbits then underclocked the recommended auto setting of 367/788 down to 355/747 just to play it safe. I just wanted to break 4000 on 3dmark05 and i do with a score of 4106, so i'm happy with that.
  8. LuckMC11
    yea..i got 4,153 with the 76.50 drivers b4..and then i downclocked it a lil bit more...and FYI...
    80.40="First of the 80 series drivers leaked from 3DChipset"..and plus..ur using that at ur own risk!!!!!
  9. Tomas
    yeah i know, i just thought i'd give em a try. I could always just uninstall them. I'm happy with what i'm at now. What are you clocked at and what temps are you getting? I'm hovering around 62c after heavy gaming.
  10. LuckMC11
    woah..the highest temperature i've gotten to was 54 degrees...and that was after half life 2 at max settings!!!!...i downclocked my drivers after i reached over 4,100 as my scores...cuz i didn't feel the need to hurt any of my hardware...even if it would take a while to hurt it..i didn't feel the need to risk it :D ..i downlclocked it to 330/700..wanted to be safe..rather than sorry :cool: :p
