Laptops for drawing
Discussion in 'What Notebook Should I Buy?' started by mraklbrw, May 10, 2020.
  1. mraklbrw
    mraklbrw Newbie
    Good afternoon.
    Which laptops are suitable for drawing as a replacement for a graphics tablet? I am interested in the accuracy of the screen sensor.
    There are many modifications of Lenovo IdeaPad C340-14IWL, as well as HP ENVY x360 13-XXX, ASUS ZenBook Flip 13 UX362FA-EL077T.
    I would like: 100% sRGB, Ryzen 5 / i5 or Ryzen 7 / i7 in the range of 1000$.
  2. Ed. Yang
    Ed. Yang Notebook Evangelist
    HP seems to have such model, but with that kind of requirement, it may break the 1000 barrier you've set, even with Ryzen CPU employed...
  3. Kyle
    Kyle JVC SZ2000 Dual-Driver Headphones
    If price is not a concern, which laptops would be in the running?
  4. Ed. Yang
    Generally most touchscreen 2 in 1s are good for drawing. It's just the additional requirements such as CPU, color accuracy as demanded by user or resolution of the screen that pushes the price higher.
    I had just placed an order for a Lenovo Chromebook C630. Not the highest or impressive on spec type(i3-8130U/ 64GB eMMC/ 15inch). But as long as it supports active pen for my mum's use, for writing Chinese character, it just suffice.
    There are many makes in the market but mostly have a common problem. Heat buildup. Hence, i wouldn't suggest anybody to go for those very slim type(where folks usually commented that slimmer it is, better portability). IMO, slightly thicker facilitates better air draw, and air flow.
