laptops battery only lasts 20mins HELP!!!
Discussion in 'Windows OS and Software' started by mtarm1, Dec 20, 2009.
  1. mtarm1
    mtarm1 Notebook Evangelist
    it was roughly the same before i installed battery bar but i just never timed it... this is my first laptop so i have never had any other brands to go of... i beleive the battery is made by sony...
    battery wear is 55.6%
    sorry for the noob question, but what settings do i need to turn of to let it fully drain the battery?
  2. jackluo923
    jackluo923 Notebook Virtuoso
    You have to adjust the critical battery level to 0%.
  3. mtarm1
    thanks, done that, i shall let it run out when i finnish using it today.
  4. mtarm1
    atm battery bar is saying total life is 41 mins and i have 1% battery left... i think its been off battery for a little longer than that though... looking much better than before thanks for all your help guys.
  5. JCMS
    JCMS Notebook Prophet
    You tried recalibrating? That should fix the non-synchronization between % left and time left
