Laptop shutdown w/Acronis Drive Cleanser running.
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Mr. Miller, Mar 10, 2008.
  1. Mr. Miller
    Mr. Miller Notebook Enthusiast
    I am not sure that I am in the right place to ask this but here it goes.
    I was using Acronis Drive Cleanser on an external HDD while my laptop came unplugged. It ran until the laptop shut down. After I plugged the laptop back in, it will not recoginze the external HDD now. I know that it did not finish cleaning it as my battery could not last that long.
    What do I do now? Is there some trick or another program that can get this HDD going again?
  2. nobscot6
    nobscot6 Wise One
    do you have vista??
    did you see if it shows up under the vista partition manager.....
    if not try downloading acronis disk director suite 10 trial and see if you can format and then wipe it....
  3. Mr. Miller
    Win XP Home.
    Extremely elementary question. Acronis Disk Director Suite 10 Trial. Should I choose run or save to download?
  4. nobscot6
    nobscot6 Wise One
    save and then run
