LAPTOP RAM Overclocking help 10875H MSI GE75 10SF
Discussion in 'MSI' started by berkkocaturk, Oct 8, 2021.
  1. berkkocaturk
    berkkocaturk Notebook Consultant
    Hello,
    I have MSI GE75 10SF with 10875H and RTX 2070 it came with 16gb 3200mhz samsung single rank jedec memory.
    I was going to buy 32gb kingston 3200mhz jedec but saw that crucial has 3200mhz cl16
    Because my laptop has advanced bios and xmp i bought it and tried XMP. With XMP i am getting memory errors on memtest and blue screens so it is definitely not stable.
    When I manually adjust primary timings to 18-18-18-36-560 on 1.35V it works i have tested memtest and prime95 so i am mostly sure that it is stable.
    Has anyone ever tried ram overclock on this 10875h cpu what can i do i want to use the XMP and most importantly i want it stable.
    I have tried bumping up the voltage to 1.5V overclocking this ram but no setting booted over 3200mhz.
    Does this cpu and memory controller can't handle ram over 3200mhz and cl16 ? does anybody have experience.
    Is it possible that the motherboard is setting wrong subtimings and it is why i am getting the errors?
    Any help is appriciated. Thank you.
    Not stable XMP CL16 https://imgur.com/a/49sszHV#4vWLDTT
    Looks stable CL18 https://imgur.com/a/YnNyJdV
  2. NeXt3R
    NeXt3R Notebook Evangelist
    io2 voltage ,.,xmp "ram 1.35V"
    gear 1
    on msi forum is guide .,,.i try find him
    edit
    3200+ - gear2 - lower performance !
  3. NeXt3R
  4. berkkocaturk
    gear 2 is 11th gen
    I do not see gear option .
    how to adjust vccio?
  5. NeXt3R
    what do you have in the OVERCLOCK DOMAIN?
    only SA offset ??
    I think 10th vccio1 and vccio2 ??
    or SA offset from 1.05V - need more for stability "around max 1.2-1.35 V" old platform
    check HWINFO or bios for actual voltage on SA
    edit
    if 1.05V ,.,try add offset + 100mV on UNCORE domain "in MSI bios"
  6. berkkocaturk
    https://imgur.com/a/DDtl5w6
    These are the pictures of my bios which voltage you are referring to is it uncore? Will raising uncore get me stable at cl16
  7. NeXt3R
    MSI - UNCORE domain is "System agent" - this contains + memory controller
    defaults - 1.05V
    most this sensor information / setting missing on MSI "IO / SA voltage / DDR voltage is on some MSI locked / XMP not works "
    try HWMONITOR in bios or HWINFO in windows
    try to verify SA VOLTAGE "this too sometimes missing - no sensor"
    ,.,.from 1.05V "OFFSET" + 100mv - 1.15V SA -example
    not need more than 1.15V "or 1.2V max "notebook limits"
    1.35V max -- for desktop users "24/7" + OC
    edit
    DDR voltage from XMP profile - 1.35V "MAX" for better results
    if the XMP profile would work properly on the MSI would automatically increase - IO / SA voltage
    but this AUTO is sometimes -- above SAFE range :D
  8. NeXt3R
    AIDA // CPU-Z - verify available SPD for your memory
    XMP profiles ??
  9. NeXt3R
    or alternative tuning
    SA DOMAIN -- SA TRAINING and enable CL tuning// others
    use your profile 18-18-x-x "ram profile CUSTOM"
    after 3x reboot you have new profile "maximum" from AUTO-TUNE
    ,.,.bad RAM training or boot-loop - CMOS reset "45s power button"
    4W4K3 likes this.
  10. berkkocaturk
    Added thaiphoon picture too on the imgur album
