Laptop power needs
Discussion in 'Gaming (Software and Graphics Cards)' started by ng80092a, Jul 8, 2021.
  1. ng80092a
    ng80092a Notebook Enthusiast
    I've seen this laptop Tongfang GM7MG0R has an RTX 3060 with 115W + 15W of dynamic boost.
    Together with 45W of CPU, it amounts to 175 W.
    However the laptop power adapter has 180W only, how is this enough for all the elements to function?
    Can someone provide information on the safety/reliability of use on this?
  2. JRE84
    JRE84 Notebook Virtuoso
    175w<180w so yes
    manufactures are not stupid
  3. Ifrin
    Ifrin Notebook Evangelist
    What about other components (Screen, Mobo, RAM, Disk, WiFi ) they need power too.
    @ng80092a
    My MSI (i7 10750H, RTX 3060 115+15W) came with 230W power adapter, 180W under full load may not be enough and laptop can drain battery.
    Check with your seller, maybe they offer 230/240W replacement.
    JRE84 likes this.
  4. JRE84
    i think they throw all that into consideration..
    i have been gaming on laptops for 20 years and not once has the power supply been short...they have laptops that drain battery at the same time and thats what we have here its not uncommon nor an issue as it drains slowly...my msi laptop used battery while gaming on ac...good for a 4 hour session..
    if not...
    no idea never seen this
  5. JRE84
    https://www.reddit.com/r/Alienware/comments/8j1jj8/battery_draining_while_plugged_in_when_playing/
    yeah if you get a bigger power supply it looks like it wont also drain the battery
  6. hfm
    hfm Notebook Prophet
    raz8020 and Papusan like this.
  7. JRE84
    does this mean it would throttle? im learning too :p
    hfm likes this.
  8. hfm
    Maybe. All I'm aware of off the top of my head is they also had to steal power from the battery to maintain performance under load. I guess eventually when the battery went to zero there might be power throttling. I'm just left wondering why they release them in that state. I suppose nearly all of their customers would not experience this, and also not even be aware of it when buying since they aren't by and large the niche community that consumes all these things. I mean It's gotta be not harming sales and profits or they wouldn't continually keep releasing products with this issue.
    JRE84 likes this.
  9. Papusan
    Papusan Jokebook's Sucks! Dont waste your $$$ on FILTHY
    Many buying the brand name. If it works correctly or not doesn’t matter.
    Spartan@HIDevolution and raz8020 like this.
  10. krabman
    krabman Notebook Deity
    Tongfang does love their small power supplies. Mine came with a 230 and it gets very hot; enough so that an early demise wouldn't surprise in the slightest. Eluktronics swears the stock supply will hold up but my thinking is an old 330 I've got in the closet is the backup plan I'm fully expecting to implement.
