LAPTOP KEYBOARD SHIFT KEY PERMENANTLY PRESSED (NEED HELP TO DISABLE LAPTOP"S KEYBOARD
Discussion in 'Accessories' started by gust0007750, May 30, 2020.
  1. gust0007750
    gust0007750 Notebook Consultant
    MY MSI GT "S LAPTOP "S KEYBOARD HAS AN ISSUE WITH THE SHIFT KEY ACTING LIKE IT IS PERMENANTLY PRESSED I AM TRYING TO DISABLE THE LAPTOP KEYBOARD BY UNINSTALLING OR DISABLING THE PS AT ENHANCED PS KEYBOARD WHICH IS THE LAPTOP"S KEYBOARD THEN RESTARTING BUT THE WINDOWS AUTOMATICALLY REINSTALL IT AND I ALSO TRIED INSTALLING IRRELEVANT DEVICES THAT SHOULD NOT FUNCTION WITH IT BUT THE MOMENT I SHUT DOWN OR RESTART ALL THE CHANGES ARE REVERTED BACK TO SUQARE ONE I TRIED THE GPEDIT MISC COMMAND BUT I GOT AN ERROR I JUST NEED TO DISABLE THE LAPTOP KEYBOARD PERMENANTLY I LOOKED EVERYWHERE FOR A SOLUTION AND NOTHING SEEMS TO WORK I WOULD APPRECIATE YOUR HELP AND THANKS
  2. kojack
    kojack Notebook Virtuoso
    If it's a hardware issue you need to replace the keyboard.
  3. TheReciever
    TheReciever D! For Dragon!
    caps lock
    If the keyboard is busted then uninstall it.
