Laptop for first year College student
Discussion in 'What Notebook Should I Buy?' started by frogboy2727, Apr 1, 2011.
  1. frogboy2727
    frogboy2727 Notebook Enthusiast
    I'd like to purchase a laptop, for my nephew. I would prefer a laptop, with a good trackpad, intergrated graphics, backlit keyboard and good battery life.
    General Questions
    1) What is your budget?
    $625
    C, prefer 14"
    a. Netbook; 10” screen or less
    b. Ultraportable; 11" - 12” screen
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15" - 16" screen
    e. Desktop Replacement; 17"+ screen
    USA
    a. Like:
    b. Dislike:
    I'm open to any brand.
    Yes
    Taking notes in class, college projects
    It has to be mobile
    No
    As many as possible, with a standard battery pack.
    Purchasing on line is preferred.
    11) What OS do you prefer? Windows (XP or Vista or Windows 7), Mac OS, Linux, etc.
    Windows 7.
    Screen Specifics
    Standard resolution.
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. If you are unsure of what to purchase, we would highly recommend you check some notebook screens before you buy to see what you like. You may also wish to take a look at the notebook screen guide for more information.
    •Netbook resolution: WSVGA
    •Actual resolutions: 1024x600 and 1024x576
    •Offered on Netbooks 10" and smaller
    •Netbook standard resolution. This is the lowest resolution available, and is designed to easily read text and icons on smaller-sized netbook screens. However, this leads to a somewhat “crowded” display that can generally only handle one visible window at a time. Typically not available on larger machines.
    •Standard Resolutions: WXGA, HD, 720p
    •Actual resolutions: 1280x800 and 1366x768
    •Offered on larger Netbooks and Notebooks up to 16"
    •Lower resolution screens offer big text and icons that are easy to read. Less stuff fits on the screen, which translates into more scrolling. Multiple windows can be worked with, though they may have to overlap some.
    •Midrange Resolutions: WXGA+, HD+, 900p
    •Actual resolutions: 1440x900 and 1600x900
    •Offered on all Notebooks. Keep in mind text will be very small on a 12" WXGA+ notebook.
    •A set of in-between resolution options that are found on some machines. Considered base resolution on 17" inch and higher laptops. Text and icons are smaller than standard resolution screens, and more windows fit onto the screen. These resolutions are very good for working with multiple windows side-by-side, without having to overlap them.
    •Maximum Resolutions: WSXGA+, WUXGA, FHD, 1080p
    •Actual resolutions: 1680x1050, 1920x1200 and 1920x1080
    •Offered on Notebook 15" and larger
    •On these screens text and icons will be very small. Text can often be hard to read, though some do like it. A very large number of windows fit on the screen, and there will be little need to overlap any of them. Max resolution screens are good for applications that require high detail (CAD, graphics editing, etc.)
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen?
    Non-glossy preferred
    Build Quality and Design
    No
    Next 2 months
    3-4 years
    Notebook Components
    17) How much hard drive space do you need; 80GB to 640GB? Do you want a SSD drive?
    320GB - 500GB
    18) Do you need an optical drive? If yes, a CDRW/DVD-ROM, DVD Burner or Blu-Ray drive?
    CDRW/DVD-ROM
  2. Sxooter
    Sxooter Notebook Virtuoso
  3. sugarkang
    sugarkang Notebook Evangelist
    Buy two cheap notebooks. One now and sell it in 2 years. Use that money and buy another one. Any AMD-e350 offerings look good.
