Laptop for Engineering Student (CSE)
Discussion in 'What Notebook Should I Buy?' started by Saurav Karmakar, Jul 8, 2018.
  1. Saurav Karmakar
    Saurav Karmakar Notebook Enthusiast
    What about warranty and stuff? I guess overall it will cost me more than my budget
    Vasudev likes this.
  2. Mobius 1
    Mobius 1 nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ⎬⎛⎝⎠⎞⎨
    That's one downside.
    I'd recommend if you want to stick with the indian resellers, look for something that has a GTX1060 6GB (not sure if the 3GB slower version is on laptops)
    Vasudev likes this.
  3. 9ac3
    9ac3 Notebook Consultant
    I would also like to recommend Acer Nitro AN515-51. It seems to fit your budget and other major requirements: https://amzn.to/2mfuHmy. Most importantly, it's on a deal on Amazon Prime.
  4. 9ac3
    Btw there's a Clevo reseller in India called Azom Systems: http://www.azom.systems/#about-us. They only seem to be offering two models however. You can get a quote from them on the specific models they offer.
    Vasudev likes this.
  5. Saurav Karmakar
    @Mobius 1
    I contacted them, they quoted around $1693 or Rs 1,15,876 that's way over my budget. There is below mentioned specs which is their starting config.
    15.6" Exigo Configuration
    Azom Laptop
    Exigo
    Clevo Barebone
    P750TM1
    Display
    15.6” IPS Full-HD 1920x1080 60Hz Matte (anti-glare)
    CPU
    Intel Coffee Lake Desktop Grade i3-8100 4Core 4Thread 3.6GHz
    GPU
    nVIDIA GTX 1060 6GB GDDR5 MXM
    RAM Slot 1
    8GB 2666MHz DDR4
    RAM Slot 2
    -- Empty --
    RAM Slot 3
    -- Empty --
    RAM Slot 4
    -- Empty --
    Storage 1
    SATA 2.5” 1TB 7200rpm HDD
    Storage 2
    -- Empty (SATA 2.5" HDD/SSD) --
    Storage 3
    -- Empty (M.2 PCIe/SATA SSD) --
    Storage 4
    Intel Wireless-AC 8265, dual band, 2x2 + Bluetooth 4.2
    Sound
    Sound BlasterX Pro-Gaming 360, ESS SABRE Hi-Fi DAC headphone audio, 2 x Speakers
    Trackpad
    Synaptics SecurePad, Integrated Fingerprint Sensor
    Card Reader
    6-in-1 Push-Push Card reader
    Keyboard
    Customizable backlit RGB, anti-ghost keys
    Camera
    2.0M FHD Video camera
    Optical Drive
    None
    8 cell (82Wh)
    Operating System
    Microsoft Windows 10 Professional 64-bit (Pre-loaded)
    Sub Total
    ₹ 98,200/-
    Tax @18% GST
    ₹ 17,676/-
    Total
    ₹ 1,15,876/-
    Warranty
    1 Year (Default)
    1+1 Year (Additional ₹ 9,000/- plus tax)
    1+2 Years (Additional ₹ 15,000/- plus tax)
  6. Saurav Karmakar
    Rather than that model I can go for the refreshed version Acer Nitro AN515-52
    Problems
    Thermal Design (which is very important for a gaming laptop)
  7. 9ac3
    If there's a newer model at a cheaper price then go for the newer one.
    Not sure why you think thermal design is a problem, as according to Notebookcheck the laptop "makes hardly any noise under low load and while idling, and it hardly heats up even when under load." See here for the review: https://www.notebookcheck.net/Acer-Nitro-5-7700HQ-GTX-1050-Ti-Laptop-Review.251846.0.html.
  8. Vasudev
    Yep he can but import duty as you will be very high. The OP can come and go to US with that kind of money.
    3GB is slow and most of them will be crippled by design. So I think 1050ti 4GB will be more than enough. My cousin's 1050Ti mobile variant destroys my 980M.
    I'd not recommend that atleast in India since they often go/follow Click Bait and refuse SW/HW support on problematic lappies.
    @Saurav Karmakar Its MSI or Dell with GTX 1050 ti will do. Have you asked at local shops for exact price list for June/July?
    I recommend you choose 1050Ti which has more cores and higher clock speeds than 1050.
    Saurav Karmakar likes this.
  9. Saurav Karmakar
    I will be visiting official retailers as well as other shops in Nehru Place on Sunday for prices,discounts and what not. I was using Internet to gain as much expertise as I need before buying. As you know, the people in the shop (in India) doesn't have much expertise and if they find you're less aware they can make fool of you. So.
  10. Vasudev
    People always take me for a fool when I visit any shops/malls looking for electronics. They say so much and I ask 2-3 little questions about the product(s) to which they don't answer and I answer them myself and then they don't say absurd things to me. Happened to me always!
