Laptop cleaning / 17 R4 Vinyl skin
Discussion in '2015+ Alienware 13 / 15 / 17' started by Shozuki, Jan 11, 2018.
  1. Shozuki
    Shozuki Notebook Consultant
    Hey guys, back again with another couple of questions...
    my arm rest under the keyboard loves them palm prints! whats best to clean them off??
    Also, D-Brand only seem to sell skins for 13 and 15 AW models, anywhere else to get some for the 17?
    Thanks!!!!
  2. VICKYGAMEBOY
    VICKYGAMEBOY Notebook Deity
    @Shozuki check this out http://www.decalrus.com/
    FYI i never went for any branded skins, i bought carbon fiber wrap from amazon and removed my touchpad assembly, and did it myself, finished in 3 dollars.. Yes u have to be patient when cutting and sticking without air bubbles.. but its better then spending 20 dollars for a skin..
    Pete Light, Vasudev and Shozuki like this.
  3. Pete Light
    Pete Light Notebook Deity
    The absolutely best thing to clear those prints is this:
    https://www.amazon.co.uk/gp/aw/d/B0...ns+cleaner&dpPl=1&dpID=41CqmEvVU0L&ref=plSrch
    With these:
    https://www.amazon.co.uk/gp/aw/d/B0...ning+cloth&dpPl=1&dpID=517wZcovs0L&ref=plSrch
    Well worth the money, I've tested a lot of products but this restores it to looking new everytime! (Just be careful not to snag any keys when using the microfibre cloth on the keyboard)
    Sent from my SM-G935F using Tapatalk
    Shozuki likes this.
  4. quickie
    quickie Notebook Evangelist
    Baby wipes and a towel is the best thing, the wipes remove all the oil and won’t mess the finish up. Just dry it with the towel, it doesn’t get soaked but it gets a tad damp.
    Shozuki likes this.
  5. Pete Light
    Careful that those baby wipes are just pure water though, some chemicals used in those could eat away at the Matt finish over time
    Shozuki likes this.
  6. quickie
    I use the non scented ones, they aren’t as wet as normal. And I dry it immediately, I think alcohol wipes are
    more abrasive then a baby wipe.
    Shozuki likes this.
  7. Shozuki
    Thanks guys I've opted for Mr. Light's suggestion and Mr. Gameboy suggestion for a skin.
    I want to use the Laptop for work and play but need it to scream Gamer a bit less lol hence wanting to make it a bit more understated...
    Pete Light likes this.
  8. InvoluntorySoul
    InvoluntorySoul Notebook Consultant
    all you need is a wet towel....
