L502X - eSata port - port multiplier works?
Discussion in 'Dell XPS and Studio XPS' started by user54, Jan 14, 2012.
  1. user54
    user54 Notebook Enthusiast
  2. capitankasar
    capitankasar Notebook Deity
    dont know about connecting two devices at a time to that port since I didnt tested it.
    however I can tell, since I replaced the optical drive with a second hdd caddy, some rare times, I connect the stock optical drive using a cable to the eSata/usb combo port.
    it works fine, can even boot media at the bios, it also power the optical drive thing without external power.
    in your case , when conecting two or more drives to the esata port may require external power suply to power the drives.
  3. rabbitz
    rabbitz Notebook Consultant
    I think he means whether it can function as both an e-sata and usb port at the same time (i.e act as two separate ports) as opposed to just being a single port that can accept either esata or usb cables.
    edit: ok so after doing some reading, port multiplier is just a feature that allows devices physically connected to a single sata controller to see it as more than one.
    according to this site, there is no way to really tell unless you ask dell or test it yourself (or if someone else has already tested it and confirmed whether it has port multiplier or not).
  4. ClearIzzy
    ClearIzzy Notebook Geek
    Tried that dock on my L501X and it didn't work. It did detect one of the hard drives but not both.
  5. rabbitz
    Did you have the drivers installed? You need the intel rapid storage technology I think...
  6. user54
    ok so looks like port multiplier is not active on the l502x.
    anybody attached a sata drive to one of the usb3 ports with an appropriate adapter? how did it perform? these kinds of adapters are around £20 over here.
  7. felipe_carmo
    felipe_carmo Newbie
    Sorry to tell that mate, but you can only see both hard drives when you are using the USB cable.
    Using the eSata, you can only see ONE of them.
    I used to have a ASUS G53, which was one of the best laptops on the market 2 years ago.
    I now have a Dell XPS 702X... which should support most of the "top of the line" technologies from 2 years ago". =/
    I will contact DELL support tomorrow to check if there is any driver that could possibly unlock this function on the laptop`s motherboard.
    I hardly believe I will have success, but I will try anyway.
    I let you know about the answer.
