L140MU - ca. 36h on battery + possible Intel ME problem (looking for contact with Clevo)
Discussion in 'Sager and Clevo' started by marcin321, Oct 10, 2021.
  1. marcin321
    marcin321 Notebook Guru
    Hi all,
    If somebody is looking on info about L140MU - I provided some reviews (below I provide links from Google Translate to two main articles, which thx to it are translated from Polish):
    * initial thoughts - https://www-salon24-pl.translate.go...r_sl=pl&_x_tr_tl=en&_x_tr_hl=en&_x_tr_pto=nui
    * setting up under Linux (got up to mentioned ca. 36h) - https://www-salon24-pl.translate.go...r_sl=pl&_x_tr_tl=en&_x_tr_hl=en&_x_tr_pto=nui
    (notes: to open Google Translate page in browser you will have probably disable some tracker protections in browser).
    I'm writing this post because noticed that C9, C10 and SI0x states are not available. System 76 mentioned, that it could be because of disabling Intel ME with HAP bit. Does anyone experienced something similar with Clevo laptops with Intel 11-gen?
    It looks, that BIOS support is not extremely good (not many options and it's not to disable for example USB to save energy), also software for controlling fan under Linux is not perfect (I opened some tickets to Tuxedo, but till now they have driver in "light" Java Script...)
    Do you know maybe some Clevo vendors, who could speak more technically with Clevo about such things? I would like to get 40h on battery :)
  2. Blacky
    Blacky Notebook Prophet
    Only if Sager or Mysn / XMG sells them, they have the biggest say with Clevo.
