Kryonaut... holy crap
Discussion in 'Dell' started by laptopnoob678, Jun 29, 2020.
  1. teksurv
    teksurv Notebook Guru
    I believe Liquid Metal is sold under the Conductonaut brand.
    kojack likes this.
  2. custom90gt
    Conductonaut is Thermal Grizzly's Liquid metal thermal paste, there are many others from other companies. Kryonaut does not need a damn/barrier like a liquid metal would.
    kojack and Papusan like this.
  3. laptopnoob678
    laptopnoob678 Notebook Consultant
    So in GTA V with Turbo disabled and lowest settings (how I usually play), I get GPU and CPU both below 65C (light fans). It's definitely running cooler than it was before with stock and/or MX-4
    With Turbo enabled and lowest settings, I get 70C on the GPU and up to 85C on the CPU
    With Turbo enabled and highest settings, I get about the same as on the lowest settings. CPU is a bit lower, mostly below 80C
    GPU is using Arctic MX-4, not Kryonaut since I never had issues with the GPU getting too hot with MX-4.
  4. Deks
    Deks Notebook Prophet
    No, Kryonaut won't really spill and it's a pretty 'regular' thermal paste, but it seems to be better than your average thermal paste.
    If you were to use liquid metal however, I'd definitely recommend a foam barrier to prevent spillage... but if Kryonaut does the trick, stick to that instead.
    kojack likes this.
  5. kojack
    kojack Notebook Virtuoso
    I'm going to try the kryunaut. Thanks.
  6. TheQuentincc
    TheQuentincc Notebook Evangelist
    I read somewhere that kryonaut isn't good for longevity, I personnaly use Noctua NT-H2 thermal paste which is a lot better than my MX4 but not as great as liquid metal :)
  7. Papusan
    Grizzly Kryonaut will pump out faster due the thinner and creamy consistency. With laptops worse cooling vs. good desktop cooling this is doomed to happen faster. der8auer is shareholder in Grizzly company and he recommend re-paste after 1 year due mentioned reason. This on desktops who have better coolers/better fits/better pressure/better cold plate.
  8. kojack
    What is carbon based pastes like?
  9. taraquin
    taraquin Notebook Consultant
    Kryonaut on GPU works good aswell, I got a few degrees drop going from MX4 to Kryonaut on laptop gpu :)
    About longevity:
    No degradation on one of my laptops after 2 years, same on one of my desktop after a year. However, but systems don't exceed 80C during load, typically stay around 60-75C.
  10. King_Khan
    King_Khan Notebook Consultant
    I can confirm it works well.
    It made a dramatic difference in temps with my xps 15 9560.
