Kryonaut and Arctic Thermal Pads on Gigabyte 2070
Discussion in 'Desktop Hardware' started by Zymphad, Apr 29, 2019.
  1. Zymphad
    Zymphad Zymphad
    So just wanted to give feedback on trying to improve thermals on Gigabyte 2070.
    Not sure if it's worth it. The TIM on 2070 seems pretty good to begin with.
    I have OC 210/600 on Afterburner, during Division 2 @ 1950-2050 on core and 7600 on Memory runs around 76C fans @ 60%.
    With the Kryonaut and Arctic Thermal 0.5mm thermal pads (6 w/k) dropped to around 69C.
    Dunno if that would be worth it to you, considering it doesn't thermally throttle at 76C.
    What would make a difference is removing the shroud and replacing the fans with 2 120mm fans. But that would require some soldering since the pins on the 2070 are smaller than the normal fan 4 pin.
    Mr. Fox likes this.
  2. Zymphad
    Zymphad Zymphad
    Used Afterburner to limit voltage to 0.975 v. Sits at 1980 mhz w/600 on memory. Temps dodo to 65C. Voltage adjustment is the way to go to reduce temps on Gigabyte.
    Mr. Fox likes this.
  3. Mr. Fox
    Good stuff. Thanks for sharing your success.
