Kingston SSDNOW V200 Is Having Serious Performance Problems
Discussion in 'Hardware Components and Aftermarket Upgrades' started by takasniper, Dec 3, 2011.
  1. takasniper
    takasniper Notebook Guru
    Just installed my kingston ssd and love it so far. Booting into w7 used to be 1 minute and 35 seconds. Now I boot into w7 around 38 seconds. My question is WEI is giving me a rating of 5.9 for "Disk data transfrer rate," does that sound right or is something wrong? I know my SSD isn't that fast but its giving me the same rating when I had my 5400rpm HDD installed.
    Moderators note:
    Four people now have stated that their Kingston V200 has serious performance problems. This thread is to discuss the issue.
  2. namaiki
    namaiki "basically rocks" Super Moderator
    If you click "View and print detailed performance and system information", do you get a remark like the following?
  3. takasniper
    No in the note field mine said this "Caution: Based on the results of the WinSAT Disk assessment, your system drive may have slower response times under some workloads. Performance results will depend on the specific applications used and the amount of memory available. If your experience is satisfactory, no action is needed."
  4. namaiki
    Which drivers? Have you made sure that your SSD is aligned?
  5. Phil
    Phil Retired
    Please install Intel RST latest version from Intel.com.
    If that didn't improve WEI then post a screen shot of AS-SSD without running the benchmark.
    For my own interest: will you post a CrystalDiskMark 3x100MB screenshot please?
  6. takasniper
    Sorry Namaiki I'm a newb but what do you mean "SSD is aligned?"
  7. takasniper
    Hi Phil I installed the Intel RST latest version. But still get a 5.9 am I suppose to config anything in the RST program? Also what is AS-SSD, also I never used CrystalDiskMark, but I'll try.
    p.s I did go under the manage option in RST and it showing this information. So I know its on sata III.
    System disk: Yes
    Password protect: No
    Disk data cache: Enabled
    Native command queuing: Yes
    SATA transfer rate: 6 Gb/s
    Physical sector size: 512 Bytes
    Logical sector size: 512 Bytes
  8. Phil
    Phil Retired
  9. takasniper
    Thanks Phil. I will report back with my findings
  10. Phil
    Phil Retired
    OK. By the way, is this a clean install or a cloned one?
